Electrical/charging problems
Old Dec 9, 2008 | 08:01 PM
masterbeavis's Avatar
masterbeavis
Yes, they were closed. I think the ignition system has given up the ghost, the truck was not wanting to start prior.
Old Dec 9, 2008 | 11:23 PM
wyoming4x4's Avatar
wyoming4x4
Brandon need to check your grounds. make sure your battery is grounded to frame and engine. One little trick is to use you jumper cables as a extra ground and if it improves all of a sudden something is up and follow through problem. Is your positive cable getting really hot in short amount of time. Could be bad connection. If ground getting hot in short amount of time investigate problem. might be bad ground or corroded ground. Need a meter to really help troubleshoot.
mr.noodi
Electrical Systems/Wiring
Feb 2, 2013 11:19 PM
dobeydude
Jan 29, 2013 08:22 PM
3wildboys
Feb 2, 2012 07:04 PM
04X
Apr 9, 2009 10:34 PM
mikehalll
Jan 12, 2007 09:26 AM
