F150 Helllppp
Old Nov 26, 2008 | 09:20 PM
ANNOYEDBYF150's Avatar
ANNOYEDBYF150
Exclamation F150 Helllppp
04 F150 With 5.4. When I Am Coming To A Stop The Tack Is Dropping And Sometimes Results In A Stall. Wtf Is Going On????
Old Nov 27, 2008 | 11:53 AM
xjcamaro89's Avatar
xjcamaro89
You have anymore info, like and mods, you got a K&N, might be the MAF gunked up with filter oil, when was the last time all fitlers were changed, did this just start happening on a certain tank of gas? Things like that. Let us know.
Old Nov 27, 2008 | 09:09 PM
ANNOYEDBYF150
There are no mods pure stock. About a week ago it started slow cranking. So i had my battery tested and it was only reading 11.3. So I got a new battery. Now the lights dim when it idles. when I come to a stop it stall not everytime but a couple times a day. It now idles around 400 rpms. If i tap the gas it will almost stall when the rpms drop. The air filter is clean I am not sure about the other filters I just got the truck a few months ago. I hope this will you help me lol thanks for everybodys time Happy Thanksgiving
Old Nov 28, 2008 | 06:48 AM
benningstspeed1.0's Avatar
benningstspeed1.0
you will probly have your pcm reflashed. the idle and accel are controled by the TB and that is all electronic
Old Nov 28, 2008 | 08:49 AM
xjcamaro89's Avatar
xjcamaro89
Might want to have your alternator checked as well
Old Nov 28, 2008 | 10:03 AM
FTE Ken's Avatar
FTE Ken
Sounds like a bad alternator, which in turn ruined the battery.
Old Nov 28, 2008 | 08:48 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
agree, but it wouldn't hurt to clean your throttle body.
just use some rubbing alcohol and when you re-install, torque to 10 ft-lbs
Old Nov 30, 2008 | 03:31 AM
mattd17's Avatar
mattd17
just by chance was your battery light on?
i ask this because i just had this happen to me a few weeks ago.... my battery died, and i was in a hurry to change it out, and managed to forget to hook up the lead from the alternator to the battery.....
i felt like a dumb a$$ when i saw what i had done..... only reason i found it was because i had bought a new alternator, and figured i would be safe and unhook the battery to install the alternator.....
i know, its embarrassing, but i just wanted to share it incase you have the same thing going on.
