Crankshaft Issue
Old Nov 25, 2008 | 06:09 PM
johnnydmetal's Avatar
johnnydmetal
Crankshaft Issue
I've got a 360 FE that I’m stroking out with a 390 crank, pistons, and 428 rods. I got the crank by swapping my old 360 crank with my machinist's shelf stock.
All the resizing and machining is done so here’s my problem.
While assembling the crank, rods, and pistons I found the front bolt on the crank was the incorrect length because when I tried to back it out it damaged the internal threads. There was galling on the bolt and when I chased the internals there was some damage there too.
I dare not run the new correct bolt into the hole as I'm sure it would be screwed up too. Basically I don't trust torking on them to turn the engine by hand.
The thread size is 5/8 x 18.
The wrong bolt was 2 inches the correct bolt is 1 3/4 long. The factory pilot hole in the crank is 2 1/2 inches deep. Where as the threads only go the 1 3/4 inches.
So is my crank shot?
If not what size threads can I re-cut to safely and have strong new threads?
Or
Do I need to just take it back to the machinist?
Thanks
John
Old Nov 26, 2008 | 04:31 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well it wouldnt have mattered if the wrong bolt was longer....it wouldnt have damaged the threads in the crank..It would have just bottomed out in the hole.. Unless you over Torqued it? seems to me you cross threaded it? I would take it back to my Machinist and with any accesories you have that hang on the end of the crank...Because that hole has to be true to the crank or it will be dangerous and cause major Vibration..
He
'll have to open the hole up to the next size... Rather it be SAE or a Metric size as to not take out to much material..and open up any holes in your Damper and Pulley (Pulleys) depending.. JMO..
~Russ
Old Nov 26, 2008 | 05:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The thread size is 5/8 x 18. The wrong ( ) bolt was 2 inches the correct bolt is 1 3/4 long. ( ) The factory pilot hole in the crank is 2 1/2 inches deep. Where as the threads only go the 1 3/4 inches.
Thanks
John
377850S .. Bolt, Damper to Crankshaft
National Fine Thread / 5/8" -18 x 2" / Thread length: 1 1/2"
Fits: 1968/76 F100/350 360/390 / 1965/71 Passenger Cars w/390/410/427/428's.
355721S .. Bolt, Damper to Crankshaft
National Fine Thread / 5/8" -18 x 1 1/2" / Thread length: 1"
Fits: 1965/67 F100/350 352 / 1965/67 352 Galaxie/LTD
Better make sure you have the correct crankshaft.
jbancroft
Dec 28, 2014 02:57 PM
johnnydmetal
Jan 21, 2013 05:48 PM
Finger__Rachet
Jan 1, 2013 07:08 PM
ramarado
15
Nov 14, 2007 12:09 PM
jbirklid
22
Apr 2, 2007 12:57 PM
