Sponsored by: Real Truck
Recon quality fitment installation
Old Nov 25, 2008 | 12:16 PM
BMWM1's Avatar
BMWM1
Just installed new recon led turn signals because one of the oem units was busted when I purchased the truck about a month ago.The fit and quality were good at best maybe I was expecting to much I dont know.They are not a bad product but I expected the quality to be there since everyone rates them so highly.Just my .02 worth
Im now going to install the recon cab lights and I hope they are a quality product I hate knocking holes in my roof for a poorly made unit.
Any tips from installers that have done this before would be greatly appreciated.
Im fairly new to ford and generally only work on BMWs so I maybe over reacting a little to the new engineering.TIA
Old Nov 25, 2008 | 12:31 PM
Diesel Smoker's Avatar
Diesel Smoker
Yes I agree recon turn signal lights fit like **** If you can find some place to buy your cab lights not recon you'll be better off in the long run.
Old Nov 25, 2008 | 12:39 PM
BMWM1's Avatar
BMWM1
Ive already got the recon lights for the cab just not to crazy about installing them after the turn signals
There is a guy on ebay selling new oem kits.I may go that way instead.Thanks
Old Nov 25, 2008 | 12:47 PM
riggz's Avatar
riggz
Unless you went with the full kits, the Recon smoke lenses are fine for the cab as they use the OEM base. That's the best route to go IMO.
Old Nov 25, 2008 | 12:53 PM
BMWM1's Avatar
BMWM1
I went with the full kit.Im thinking Ill be getting the oem kit.
Its $135 if you have the over head console
eBay Motors: FORD F250 F350 CAB CLEARANCE LIGHTS NEW * OEM * (item 120333223466 end time Dec-12-08 18:35:36 PST)
Old Nov 25, 2008 | 01:00 PM
riggz's Avatar
riggz
Keep in mind if someone if someone other than FORD is selling FORD products they probably have a mark up in there for profit. You can order everything that kit has direct from a ford dealership for less. The part #s for the light heads is: 6C3Z15442A and the wire harness with overhead console is: 3C3Z17C710BA. All can be purchased from directfordparts.com for $98.56 shipped. Just pick up some 5mm washers and 5mm-8 nuts at your local hardware store.
Old Nov 25, 2008 | 01:43 PM
BMWM1's Avatar
BMWM1
Thanks riggz!!!I shall do that....Ill catch on to this new ford thing soon
Old Nov 25, 2008 | 09:47 PM
dstig1's Avatar
dstig1
Yeah I used them too (same reason - bought the truck and they were broken) and thought the fit was marginal, at best. I made them work, but afterwards I noticed an annoying wind whistle when I had the windows open that was new. I've been thinking about caulking the gaps carefully with clear silicone to see if that eliminates it, but it's kinda moot in the Great White North in winter...Maybe next spring.
Since then I've seen a couple threads in the SD forum about poor customer service from Recon with problems. Makes me more wary now...
-Dave
Old Nov 25, 2008 | 10:40 PM
motometal04F350's Avatar
motometal04F350
i love the way my recon tail lights look and work. but when i installed them i shut the tailgate super slow just to be safe. good thing i did cause the pass side was sticking out way to much and the tailgate would have craked/broke it. i had to shave off about a 1/16 of the edge to clear the tailgate.
Old Nov 25, 2008 | 11:10 PM
BMWM1's Avatar
BMWM1
I will definitely reconsider future purchases from recon. They cost so little to make and come with a huge price tag one just assumes they are a quality product. Live and learn I guess
Old Nov 26, 2008 | 12:10 AM
Bernie Lomax's Avatar
Bernie Lomax
Everything I read about them is bad it seems.
Old Nov 26, 2008 | 04:29 AM
Stewart_H's Avatar
Stewart_H
I've reach my 24 hour limit for rep points, but when the time limit has elapsed, I will rep you for this post.
Good info.
Stewart
Old Nov 27, 2008 | 01:13 AM
Stewart_H's Avatar
Stewart_H
Rep points.
Thanks.
Stewart
bayou barataria
Jan 11, 2016 10:16 PM
lankford32
6.7L Power Stroke Diesel
19
May 15, 2015 11:12 AM
ZackYoung
Mar 15, 2015 06:23 AM
Tylus
Aug 18, 2014 02:25 PM
