It's ball joint time
Old Nov 24, 2008 | 09:05 PM
EMD_DRIVER's Avatar
EMD_DRIVER
My 93 couldn't be aligned last week, due to the left-lower and right-upper ball joints being in pretty bad shape. I went straight from the shop, to NAPA and bought 4 ball joints, 2 U-joints (outer U-joints need to be replaced), 2 spindle bearing kits and 2 wheel bearing seals.
I have a spindle nut socket and ordered a ball joint press. I'll have to rent the spindle-puller from AZ when I'm ready to get started.
I was unable to do the job this past weekend, due to not having the tools and also due to not being able to get my 87 started, so I could get it out of the garage.
Anyone have any tips/tricks to getting this job done and done right? I've never tackled a project like this on a 4WD and appreciate all the help I can get. It's looking like I'll be doing this by myself.
Old Nov 24, 2008 | 10:44 PM
Dave Sponaugle's Avatar
Dave Sponaugle
What front axle?
Old Nov 25, 2008 | 04:48 AM
EMD_DRIVER's Avatar
EMD_DRIVER
Originally Posted by Dave Sponaugle
What front axle?
That leads me to another question... It is IFS, so I assume it's a D50. When I went to get the parts, the guy asked me what the weight rating was on this axle. I told him the sticker said 4410. The first set of lower joints he gave me, were too small. The joints I ended up getting, were what his book listed for the 4600+ axle. What gives?
Old Nov 25, 2008 | 11:58 AM
axel 56's Avatar
axel 56
when I did mine IFS 50 I got the press from a guy and he handed me a 20 lbs sledge hammer and I needed it did one side a day
Old Nov 25, 2008 | 08:32 PM
Dave Sponaugle
Here is a pdf file from Dana about identifying and servicing the Dana 50 IFS.
http://www2.dana.com/pdf/5326.pdf
I went to your gallery to see if I could see anything, that did not work out to well though.
Old Nov 25, 2008 | 08:45 PM
Franklin2's Avatar
Franklin2
Good step by step on balljoint removal in this link.
Bronco Ball Joint Replacement - Trucks 4x4 @ Off-Road.com
Old Nov 25, 2008 | 09:23 PM
EMD_DRIVER's Avatar
EMD_DRIVER
This is a great write up!
Old Nov 25, 2008 | 10:28 PM
starmilt's Avatar
starmilt
Dave where do you find files like that. Thanks.
Old Nov 25, 2008 | 10:45 PM
Franklin2's Avatar
Franklin2
Another guy posted it in the 80-86 forum.
Old Nov 25, 2008 | 10:59 PM
starmilt's Avatar
starmilt
That is a good file.
