Tie Rod End adjusting sleve..
Old Nov 24, 2008 | 06:20 PM
afonda's Avatar
afonda
Can there be any adjustments made with the tie rod adjusting sleve?
Old Nov 24, 2008 | 06:56 PM
DCSpecial's Avatar
DCSpecial
Yes, you use that to adjust the toe.
The adjuster sleeve on the drag link is used to center the steering wheel.
The arrow is pointing to the one on the drag link:
The one under the stabilizer shock is the one on the tie rod that is used to set toe during alignments.
Old Nov 25, 2008 | 07:34 AM
afonda's Avatar
afonda
Ok... so these will have nothing to do with slop in the steering.
Thanks for the input.
Old Nov 25, 2008 | 12:06 PM
DCSpecial's Avatar
DCSpecial
Not unless the sleeve is loose, which would be very dangerous.
Worn drag link ends or tie rod ends could cause slop.
Old Jan 28, 2014 | 02:44 PM
Lex2002's Avatar
Lex2002
I found out today I have a bad tierod end on the "drag link"? Ford diagram refers to it as 3A131. Is 3A131, 3281 and 3A130 the entire drag link assembly? Im trying to figure out what the corresponding part number is at MOOG.
The alignment tech told me he could not straighten the steering wheel and align the truck without the tie rod end being replaced. Nice guy. Makes sense...just need to know which part to order.
texasjack
40
Jul 30, 2023 12:04 PM
-mywheels-
Jan 30, 2014 07:07 AM
HD RULES
Apr 5, 2011 11:56 AM
