Tie Rod End adjusting sleve..
Old 11-24-2008, 06:20 PM
afonda's Avatar
afonda
afonda is offline
Can there be any adjustments made with the tie rod adjusting sleve?
Old 11-24-2008, 06:56 PM
DCSpecial's Avatar
DCSpecial
DCSpecial is offline
Yes, you use that to adjust the toe.
The adjuster sleeve on the drag link is used to center the steering wheel.
The arrow is pointing to the one on the drag link:
The one under the stabilizer shock is the one on the tie rod that is used to set toe during alignments.
Old 11-25-2008, 07:34 AM
afonda's Avatar
afonda
afonda is offline
Ok... so these will have nothing to do with slop in the steering.
Thanks for the input.
Old 11-25-2008, 12:06 PM
DCSpecial's Avatar
DCSpecial
Not unless the sleeve is loose, which would be very dangerous.
Worn drag link ends or tie rod ends could cause slop.
Old 01-28-2014, 02:44 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
I found out today I have a bad tierod end on the "drag link"? Ford diagram refers to it as 3A131. Is 3A131, 3281 and 3A130 the entire drag link assembly? Im trying to figure out what the corresponding part number is at MOOG.
The alignment tech told me he could not straighten the steering wheel and align the truck without the tie rod end being replaced. Nice guy. Makes sense...just need to know which part to order.
texasjack
40
07-30-2023 12:04 PM
-mywheels-
01-30-2014 07:07 AM
HD RULES
04-05-2011 11:56 AM
Quick Reply: Tie Rod End adjusting sleve..
