Sponsored by: Auxito
heater core replacement
Old Nov 24, 2008 | 12:39 PM
conductor25's Avatar
conductor25
ive searched and havent found anything that says that the a/c absolutely has to be discharged and refilled. is this step necessary? i just cant see what the ac system has to do with a part that is connected to the cooling system. its just anti freeze right? thanks in advance.
almost forgot, its a 98 f-150 4x4 with 4.6 and tow package
Last edited by conductor25; Nov 24, 2008 at 12:50 PM. Reason: left out improtant info
Old Nov 24, 2008 | 01:32 PM
triton_2002's Avatar
triton_2002
welcome to FTE!
no you don't need to mess with the a/c system, pulling out the entire dash to get to the heater core should keep you busy enough....if you did'nt know that already.
Use the search above, there's plenty of posts, some with detailed instructions, about heater core replacement. Some have been able to replace it by loosening up the dash and working under/around it.
artfd
May 23, 2013 08:39 AM
robjs111
1997 - 2003 F150
Jul 22, 2010 06:05 PM
robjs111
Jul 22, 2010 04:02 PM
RTM
Jul 16, 2009 04:15 PM
elijahj
Dec 27, 2003 09:32 AM
