chopped my windshield
Old Jul 3, 2009 | 12:09 AM
  #91
keith56_cruz_cab's Avatar
keith56_cruz_cab
thanks gomes for the tip....but
I just didn't feel good about cutting out pieces of the pinch rail and leaving the glass without support in those areas.
so I cut it out and i'm re-building a new one in the right place.
I hope to have it done this weekend
Old Aug 1, 2009 | 08:51 PM
  #92
nordvik72's Avatar
nordvik72
Any new progress keith? I dont know if you have ever been to www.trivalleyautoglass.com but i found this Using Polycarbonate in this street car proved to be very tough. It resistes scractches and unfortunatly it also resists paint and glue, so to pull this off we needed to sand very carefully the edges around our patterns and use aluminum rivets too secure our lexan to the pinchweld. 1/8" or 3/16" will work, and if your shape does not have to much of a radius you can use 1/4". After sanding we painted around the edges(on the lexan) to hide the pinceweld, marked our 1/8" holes that we drilled prior. Using our own rubber gasket material we placed it over all the surrounding rivets. After several hour of fit, re-fit, and re-fit again! we finished with what looks like real glass in a custom chopped car.... They also cut auto glass with radius. just a suggestion. I did read you used lexan before but what size was it? I have also seen people heat it up in a oven and form it over something "IE" a old windshield. you would have to find a big oven possibly you would be able to use one at a local powder coating buisness.
Old Aug 1, 2009 | 10:09 PM
  #93
nordvik72's Avatar
nordvik72
How did you heat up the lexan you tried using?
Old Aug 1, 2009 | 11:08 PM
  #94
keith56_cruz_cab
I used a heat gun....it wrinkles the plastic.
I hired a glass guy he broke the first one he's on his second !
Old Aug 3, 2009 | 06:00 PM
  #95
gomes's Avatar
gomes
Take it slow.....
Old Aug 4, 2009 | 01:23 AM
  #96
AXracer's Avatar
AXracer
Keith, are these all new windshields?
Old Aug 5, 2009 | 12:17 AM
  #97
keith56_cruz_cab
yea all new.
The glass guy says that maybe they arent good glass so he ordered
what he called a pinkerton glass...I hope they are better !
Old Aug 5, 2009 | 02:16 AM
  #98
nordvik72's Avatar
nordvik72
So keith I dove right into it with you. I started cutting into the upper portion of the over hang to fit my windshield this weekend. Did a lot of cutting and i think i got it to the point where its going to work. Ill post you some pics soon. I do have some bad news though i cracked my first windshield doing all the test fitting lol. I need to order my seal to do the final test fit and weld up some supports for the top of the windshield all and all some minor metal work to clean some stuff up on the inside and A pillars and ill see what happends from there. If all fails I still have my 55 cab waiting for me to mess with.
Old Aug 5, 2009 | 06:34 AM
  #99
sdetweil's Avatar
sdetweil
yea all new.
Interesting.. the Windshield for my 55 is from Pinkerton
Sam
Old Aug 5, 2009 | 08:13 AM
  #100
vintage56's Avatar
vintage56
never heard of Pinkerton. who are they?
web search came up empty.
JML
Old Aug 5, 2009 | 08:17 AM
  #101
sdetweil's Avatar
sdetweil
No idea.. I ordered a windshield from Ebay (guy in Oregon), and when I picked it up, the receipt and name stamp on the glass says 'Pinkerton'..
sam
Old Aug 5, 2009 | 08:56 AM
  #102
BACAGrizz's Avatar
BACAGrizz
Are you sure it wasn't Pilkington Glass?
Old Aug 5, 2009 | 09:30 AM
  #103
sdetweil's Avatar
sdetweil
oops. sorry, you are right..
Sam
Old Aug 5, 2009 | 01:30 PM
  #104
vintage56's Avatar
vintage56
http://www.pilkington.com/automotive...ng/default.htm
JML
Old Aug 5, 2009 | 08:39 PM
  #105
nordvik72's Avatar
nordvik72
This is where im at "PICS"
Like i said i still have allot of cleaning up to do and i need to fit with seal for the final test. Then when i find another windshield ill give it another try.
