Arp Head Studs Is It A Fix?
Puking caused by blown head gasket OR EGR cooler failure, oil cooler failure, or it could be overfilled coolant system. Don't blame ARP for others...
I installed mine, did the EGR cooler delete, and have no problem floor it on the highest level.... not a drop of coolant loss.
By the way head gasket failure never will came with overheating problem, so I'm sure that you're looking for something else...
I actually would say that the RR kit is a must for reliability especially in order to deal with the dead-heading of the injectors that are known to happen on these engines. FASS system isn't a must unless your going to be doing bigger injectors, but good to have.
Whats a fass system?
What coolant filter are you guys recommending?
Any links to these things plus some explanations would be greatly appreciated.
I've got an 05. I'm not going to do any programmers but I am thinking of doing the egr delete and 4" exhaust. This truck has been extremely problematic and I'm up in the air as the whether or not I want to trade or spend some cash and hopefully make it a reliable vehicle.
So far I've been scared to spend the money because I don't know of anyone who's done these things and had the results of a problem free 6.0 If I'd found the V10 I want the 6.0 would already be gone.
https://www.ford-trucks.com/forums/2...rerouting.html
FASS system :
hit search, you'll find write up on it....
Coolant filter from dieselsite :
http://www.dieselsite.com/index.asp?...ROD&ProdID=324
EGR delete :
You can almost do the EGR delete for free if you do it yourself. take out the EGR cooler and put a block off plate on both ends of the egr cooler but let the coolant still flow through it. its fail proof and it doesn't cost much, its cheaper than a $700 delete kit. make the block off plates yourself, you'll see how to do it when you get it off. You can look up on ebay, I'm sure you'll find the plate/kit.
My truck was a problematic child too. You can see in my signature the mods I have, and I did almost everything in the same time to it. Since that no problem at all - knock on wood, and I'm happy to say, since that I'm thinking of the new mods ( regulated fuel return ) instead of the repairs.....
Also - there are many reasons to overheat and puke coolant (not just leaking head gaskets):
<TABLE style="WIDTH: 468pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=624 border=0 x:str><COLGROUP><COL style="WIDTH: 468pt; mso-width-source: userset; mso-width-alt: 22820" width=624><TBODY><TR style="HEIGHT: 39.75pt; mso-height-source: userset" height=53><TD class=xl27 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 468pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 39.75pt; BACKGROUND-COLOR: silver" width=624 height=53>Common Causes</TD></TR><TR style="HEIGHT: 12.75pt; mso-height-source: userset" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 468pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: silver" width=624 height=17>
- EGR Cooler leaking
- Oil Cooler plugged or leaking (which elevates oil temps AND prevents coolant flow to EGR cooler
- Blown Head Gaskets from stretched TTY bolts, most likely from excessive CP (cylinder pressure)
- Bad degas bottle cap (if you are puking coolant, you should replace the degas bottle cap after fixing the root problem).
- Clogged Radiator (air side)
- Thermostat
- Some suspect a collapsed radiator hose
- Coolant Temperature Sensor
- Injector cup
- Glow plug cup
- Warped or cracked head
- Water pump fins are split where they go around the shaft:
</TD></TR></TBODY></TABLE>
