Modular V10 (6.8l)
radiator flush ?
Old Nov 21, 2008 | 09:17 PM
britt's Avatar
britt
radiator flush ?
Guys... getting ready to flush and refill the radiator on my 2000 v-10, any tips or problems to look out for? is it okay to fefill with prestone green coolant? according to my owners manual the cooling system holds about 17 quarts of coolant... thanks Britt
Old Nov 21, 2008 | 10:02 PM
Monster-4's Avatar
Monster-4
This may help.
https://www.ford-trucks.com/forums/7...nt-change.html
Old Nov 21, 2008 | 10:19 PM
britt's Avatar
britt
THanks Monster 4....guess i'll go with green this is as confusing as the which oil should i use thread........ appreciate the link.
Old Nov 22, 2008 | 02:12 AM
RACERX7775's Avatar
RACERX7775
hey monster, does that procedure clear out the rear heat on an excursion too? i bought one of those prestone flush kits but havent cut the hose yet...
Old Nov 22, 2008 | 09:03 AM
britt's Avatar
britt
update
Monster...upon closer inspection....my truck has the gold coolant in it, i guess it was put in by the p.o. at dealership, however my truck is a 2000 model and the chart calls for the green antifreeze. would it be best to flush out the gold and go back to green, or just go back with gold? i think ford changed to gold on the 03 models. the gold wont hurt anything will it?
Old Nov 22, 2008 | 09:26 PM
Monster-4's Avatar
Monster-4
You aren't suppose to mix the green and the gold Motorcraft anti-freezes according to the label on the bottels. If you're using gold now stick with that unless you are sure you completely flushed it out before moving to the green stuff.
The gold will have a longer service interval but it is more expensive. Other then that you can use it.
Old Nov 22, 2008 | 09:32 PM
Monster-4's Avatar
Monster-4
Supposedly since it's part of the same system but I have never done it on an Excursion.
Old Nov 22, 2008 | 09:41 PM
britt's Avatar
britt
Monster...if the truck originally came with green, its been changed out to gold just before i got it (at 97000+_), now at 170.000 then i feel a little better about it. napa has the gold coming in tuesday, i'll pick up some then. thanks for the info.
berry1234
Mar 30, 2016 07:09 AM
britt
Sep 17, 2012 09:16 PM
britt
Modular V10 (6.8l)
Mar 17, 2012 06:27 PM
britt
Nov 18, 2007 05:57 PM
ledbetter
Jun 25, 2005 01:35 PM
