78' F250 Coolant Flush Method?
Old Mar 28, 2016 | 03:47 PM
berry1234's Avatar
berry1234
What is the best method to flush my old coolant from my 78' F250 400ci truck? It has the standard radiator. Thanks.
Old Mar 28, 2016 | 11:26 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Get a heater line (inline) tap kit and follow the directions, it will flush out the old fluid, but not really flush out the block very well, but should work for you.
http://www.autozone.com/landing/page...flush-and-fill
Flush and Fill Radiator Kit at AutoZone.com - Best Flush and Fill Radiator Kit Products for Cars, Trucks & SUVS
Or http://www.oreillyauto.com/site/c/de...N0185&pt=N0185
Old Mar 29, 2016 | 10:53 AM
berry1234's Avatar
berry1234
Flush & Fill In 3 Easy Steps - AutoZone.com
Or Prestone AFKIT - Flush & Fill Kit | O'Reilly Auto Parts
Thanks, I will give it a go.
Any specific way to burp the system after?
Old Mar 29, 2016 | 12:13 PM
77&79F250's Avatar
77&79F250
Get the trucks nose higher (car ramps) or a nose high parking spot in a parking lot ect..., and let it idle till the T stat opens with the rad cap off.
Old Mar 30, 2016 | 12:55 AM
Ozzie H.'s Avatar
Ozzie H.
The "best" way is to include draining the engine block if someone has installed the drain valves. This becomes more important if a chemical flush is utilized. If you still have the block plugs it will be a significant job to get the valves installed in most cases. Sometime there can be as much coolant in the engine as in the radiator. The in-line approach will work reasonably well if all you are doing is replacing the coolant and don't mind doing it long enough to get the old stuff out. But keep in mind that what is left in the engine will be almost pure tap water so you will have to check the new coolant concentration well. Also some tap waters are not really good for cooling systems. Distilled or perhaps rain water is preferable. Best wishes!
Old Mar 30, 2016 | 07:09 AM
Blue and White's Avatar
Blue and White
Lots of ways to do this. The heater line method has worked for me. My favorite is to backflush the block through the upper radiator hose. 1 1/4" or 1 1/2" pipe (PVC or iron) will fit the upper rad hose. Remover the radiator hoses, Remove the T stat, install the upper hose to the engine with pipe fittings to adapt a garden hose to the upper radiator hose and turn the water on. Let it run until is is clear. You can do the same with the radiator and heater hoses. When you re-fill, put the correct amount of concentrated anti freeze in first then add water. That way any water left in the block will not reduce protection.
A radiator flush tool like the one linked will save putting together the pipe fittings and also let you blast it with compressed air.
Also note the 400 takes a special thermostat which is usually an order part at NAPA.
http://www.amazon.com/s/?ie=UTF8&key...l_73rgf9bzvw_e
cowgirlcpa
21
May 1, 2018 09:28 PM
IDI-Charlie
Jan 17, 2014 12:43 AM
Eallend7
Mar 6, 2013 07:27 PM
DevilDocTater
Dec 26, 2011 07:35 PM
bismic
Nov 21, 2009 07:45 AM
