vac. pump??
Old Nov 21, 2008 | 09:12 PM
kent's f-350's Avatar
kent's f-350
vac. pump??
hi all, what all does this vac pump do?? just hvac controles and lock outs or does it do more? i ask b/c my lock out pulseator went bad and i lost my vaccum so i pulled the hvac hose off the tank and pluged it into the pump, bypassing the tank and whatever else it does. so do i need to un-hook the lock outs and plug the tank back in or will it work just like it is??
Old Nov 21, 2008 | 11:08 PM
Pocket's Avatar
Pocket
Vacuum pump only controls the HVAC and ESOF hubs.
camodown's Avatar
camodown
Just ESOF pulse to the hubs and HVAC. The only thing you are doing by bypassing the tank is reducing the reserve capacity on the vacuum system and causing the pump to turn on more possibly. If you don't use the pulse hubs anymore and manually lock them, just plug the port on the knuckle, and plug the vac lines and reconnect the canister. Those stupid vac pumps are a bit spendy if they die but if they do and you have manual hubs, then you can use bailing wire and tie the HVAC doors in the position you use most like I did and avoid spending $140, that is until you want other HVAC modes...
Old Nov 23, 2008 | 10:43 AM
kent's f-350
ok, thanks, that is what i thought. and no thanks on the bailing wire, i will spend the $140 on a vac pump. since i just put $2500 in it whats $140 more. lol
jeem
Aug 9, 2013 01:13 PM
genscripter
18
Jun 28, 2013 04:36 PM
Zookie400
Nov 21, 2010 05:08 AM
Sycostang67
21
Sep 16, 2010 08:57 PM
Ronin-M5
Apr 30, 2008 03:50 PM
