Back-up Lights
Old Nov 21, 2008 | 08:44 PM
rwlacks's Avatar
rwlacks
Question Back-up Lights
A little help please , My 78 F150 C-6 Tranny is blind in reverse any clue where the backup light switch is located? good bulbs and new sockets wiring looks great . When i think back i'm sure they worked before i built the tranny is it part of neutral switch or under dash??
Old Nov 21, 2008 | 08:49 PM
kingford72's Avatar
kingford72
the neutral saftey switch is on the side of the tranny were the gear selector goes in and has to be adjusted right to start the truck in neu and prk and turn on reverse lights
Old Nov 21, 2008 | 08:54 PM
rwlacks's Avatar
rwlacks
Ok So how do you this ?? Mine starts in park and neutral also
Old Nov 21, 2008 | 08:55 PM
cipsmithers's Avatar
cipsmithers
i have a 77 f150 with the c6 and my neutral safety switch is located on the top of the column under the dash
Old Nov 21, 2008 | 09:06 PM
kingford72's Avatar
kingford72
sometime in the mid 70s they moved them but the late c6s are on the side of the tranny you loosen the two mounting bolts the holes have some slot to them and with the tranny in neutral rotate the switch back and forth until you can slide a #43 drill bit in a little alinement hole I hade a switch work for starting and not backup already or maybe switch is bad Maybe switch was bypassed before you got the truck is the switch there?
Old Nov 21, 2008 | 09:55 PM
rwlacks's Avatar
rwlacks
Thanks, Yes the switch is on tranny got this truck new from Ford in 78 , I will give it a try this weekend for now it's 17 Deg. little too chilly for working on it now. If switch is bad where is best place to get one ?? NPD ? Carpenter ? I will start looking when i get a nice day i will post some Pics of a nice one owner Ranger / Explorer
Thanks again
Old Nov 21, 2008 | 10:57 PM
alconk's Avatar
alconk
Just replaced mine last week and cost was $50. from Advanced Auto Parts with 1 yr warranty. It was normally $70 but negioated because Auto Zone was $30 something. It is also A Borg Warner item. I checked with Napa and they wanted $90 and it was the same part #. Now my backup lights work too.
Old Nov 22, 2008 | 08:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/79 Neutral Safety Switches
Thru 1977, the NSS is located on the steering column.
1965/77 F100/350: C7TZ7A247A (Motorcraft SW600).
1978 and later, the NSS is located on the transmission.
1978/79 F100/350 C6: D8TZ7A247A .. NSS (Motorcraft SW1489)
1978/79 F100/150 C4: D8TZ7A247B .. NSS (Motorcraft SW1491)
Old Nov 23, 2008 | 05:24 PM
rwlacks's Avatar
rwlacks
Question
Checked position of switch today it is correct, Does anyone know what wires to place jumper on to see if its the switch ? would like to try a jumper at the {grey} plug under the hood just dont know what color wires to place this on
