clutch question
Old Nov 21, 2008 | 03:00 PM
mudder460's Avatar
mudder460
clutch question
According to my vin numbers my engine has a 10" clutch. I am planning on replacing it when I rebuild my tranny. My question is can I use the 11" instead? Reason being I plan on doing a swap to a 351w in the future and I really don't want to buy 2 clutches. If I can't use it I will just hold off on the clutch till I do the swap. Thanks!
Old Nov 21, 2008 | 03:43 PM
ridgerider3's Avatar
ridgerider3
The clutch plates are drilled and tapped for both.
I have found no difference between the two except price.
I go for which ever is cheaper.
Old Nov 21, 2008 | 03:54 PM
mudder460's Avatar
mudder460
I priced both and there is less than $10 difference. I was just hoping I could get the 11" instead of the 10", now I will be able to use it when I do my 351w swap. This makes me happy! LOL
Old Nov 21, 2008 | 04:43 PM
srercrcr's Avatar
srercrcr
Let me re-ask the question because I'd like to know too....the pressure plate and the flywheel on the 10" setup will accomodate the 11" disc?
Old Nov 21, 2008 | 10:21 PM
JimsRebel's Avatar
JimsRebel
also....Does an 11 inch disc give you more wear surface area? Or just a different Dia.
Old Nov 21, 2008 | 11:42 PM
MatCat58's Avatar
MatCat58
The 11" does give you more surface contact. I just stepped up from a 10.5 to an 11 inch about 2 weeks ago and so far it hasn't given me any trouble just remember to polish your flywheel on the new contact area otherwise you will get some wicked chatter.
Old Nov 22, 2008 | 06:50 AM
ridgerider3
Pressure plates are set for the different size clutch plates.
Not 100% sure, but i would not mix and match without some serious measuring.
Never really looked at the 10" vs the 11" to see if the parts interchange.
As MatCat58 said, take the flywheel to a good machine shop to get rid of any
imperfections so your clutch will last as as possible.
Old Nov 22, 2008 | 10:45 AM
mudder460's Avatar
mudder460
I plan on getting the clutch kit, not just the disk. This will just make things easier in the future!
Old Nov 22, 2008 | 06:24 PM
ridgerider3
Make sure it's got the alignment tool!!
Got on once that did not have it, and did not know it UNTIL after I pulled the tranny and clutch off.
Old Nov 22, 2008 | 07:12 PM
mudder460's Avatar
mudder460
I always look for that. Man I can't wait to get back to the states and start working on the truck now!!
Old Nov 22, 2008 | 07:20 PM
srercrcr's Avatar
srercrcr
Arkansas seceded?
Old Nov 22, 2008 | 07:29 PM
mudder460's Avatar
mudder460
Deployed over seas right now, half way done though. Be back workin on the truck soon!
DCP
Engine Swaps
Oct 25, 2025 05:00 AM
Ryan313
Jul 26, 2016 07:12 PM
tndallas
Apr 17, 2015 07:00 PM
mutant
Jun 12, 2014 08:07 PM
Cahlager
Sep 17, 2012 09:10 PM
