10.50 Limited Slip
No I am confused......how would we redrill the axle?????It is a full floater.....it would have splines on each end(not like a c-clip axle)......I found this but have not read through it yet
Ford 10.25 & 10.50-Inch Axle Tips - Four Wheeler Magazine
I was wondering about the 10.25 hubs going on to the 10.5...then getting disks with 8x6.5 pattern.
There are no splines one the outer end, just a flange w/ 8 holes.
If the wheel bearings are the same then the hubs might swap onto the new axle?? If not
Maybe the spindles will swap?? Lots of measuring to see if it's possible.
Moving the spring perches & shock mounts is not a big deal for me.
A disc brake conversion is looking better all the time. That's the only reason I wanted to swap the axles.
Ron the Rotor is the easiest part of the whole project. The Rotors from an E-series are exactly the same as a pickup but have 8x6.5 bolt holes. Now the only problem may come is if the wheel mounting surface different that Rodney is talking about is in the hub design. IF the wheel flange is in a different position from the two hubs then the hat distance on the rotor will be incorrect.
If thats the case....why are we not looking for an axle from an '99+ E-series....assuming they went to a 10.5 w/disks?????I am sure there are alot out there between church buses and delivery trucks......It would be an easier swap if we just have to move perches and shock mounts
I believe the 99+ are the metric bolt pattern. IDK though. I am confused on it as well. I was looking for the rotors to do a rear disc conversion like TJ did but could never find a year or the rotors. The parts stores I wend too all showed drums for 97 and erlier and metric disc from 98 on.
What year do do you get the E-series rotors from TJ?
Opp's I meant hubs. I've had axles re-drilled so i assumed the hubs could be too.
I just found these:
AutoZone.com | Shopping | Parts | Product Detail - Brake Rotor - Rear
Im going to run by there tonight and measure to make sure that they are 6.5 pattern.
I'm doing this instead:
http://blackbirdscustomtrucks.com/index8.html#6str
on
whats wrong with the 10.25 axle? i have never seen one burned up yet. unless you run them out of oil, and even then the hub bearings will go out first and the rear end is fine. as for drum brakes, they last longer than disk brakes and are cheaper to replace. dont want an arguement because i dont really care what you do to your truck, but it seems like a lot of work and no gain. disk brakes you have to change to a hydroboost brake master cylinder unit as well as mess with the rabs system. your looking at spending 2g plus pay yourself time to do it all. just put a arb air locker in it and go. thats what im gunna do soon as i get a grand to spend
#28
on
Thor'sHammer
11-23-2014 08:34 PM
stangnutlx
11-19-2014 03:13 PM
tschrubb
1999 to 2016 Super Duty
08-07-2011 09:38 AM
TexasGuy001
15
01-13-2010 03:52 AM
