how to make a 5x135mm bolt pattern wheel fit an 5x5 bolt pattern lug??
i got a set of 5x135mm frome a friend since i have to wait 2-3 weeks for my tires for the trucks wheels to come.. how can i fit them to work in the meantime ??
I double checked over on NLOC (lightnig club) it is a 11/16" drill bit. Just ream the holes bigger. If it s temp thing just regular washers, and turn lug nuts around backwards (cone out)
Can you explain that one more time? I want to do the same thing to run newer stocks but don’t wanna wait for my spacers to come in they’re on back order
Depending on what your lug nuts look like, you can turn them around and have taper pointing out, and use the flat washer, using the flat washer to push against wheel, we have 3 different types that can be used on our trucks, see pics below. this one you can turn taper out, and use washer
