gears
Old Nov 20, 2008 | 05:28 PM
da X-man's Avatar
da X-man
gears
I was looking into getting 4.30 gears for my v10 X. What kind of job is that? Are any special tools needed? What kind of acceleration differences should i expect?
Thanks
Old Nov 20, 2008 | 05:54 PM
ReAX's Avatar
ReAX
This is one of those jobs where if you have to ask, you need professional help. Either find a friend that's done this before or let a shop do it. Gear set up is critical, you need them to mesh correctly to prevent noise and premature failure. At a minimum you will need basic hand tools, feeler gauges and a dial indicator with stands.
Acceleration differences would depend on your current gear. If you have 3.73s it should feel at least 1000lbs lighter.
Old Nov 20, 2008 | 07:18 PM
gr8scott72's Avatar
gr8scott72
A few questions. Why are you wanting to change? Do a lot of towing? Have large tires? Why stop at only 4.30:1 instead of 4.56 or even lower?
You can look to pay around $750 per axle (2 if you're 4x4) for parts and labor to have a shop do it.
I changed the gears in my 2000 Durango from the factory 3.55:1 to 4.56:1 and my 0-60 time dropped by a full 2 seconds. HUGE difference!!
Old Nov 20, 2008 | 07:58 PM
ReAX's Avatar
ReAX
I think without going to 35" tires, 4.56 will be too steep. I love my 4.56s with 35" mud tires, but I think it would be too much for stock tires. The 4.30s is a powerful choice for stockish tires.
The front axle seems like the more expensive side, I brought my guy the gears and fluid. He installed and rebuilt the stock LS for just over $900. Front and rear 4.56, royal purple (break in and refill),motive gears, diff rebuild kit and Mag hytech for the rear, I figure I spent around $2000 installed.
Old Nov 20, 2008 | 09:06 PM
gr8scott72's Avatar
gr8scott72
Everyone kept telling me that 4.56:1 was too low in the Durango. I was on the stock tire size. I have no regrets. I love it. I know have tires that are about 2 inches taller than stock and it will still out pull my Excursion with the 7,000 lbs trailer behind it. (Out pull, not out tow. The Excursion is much more stable.)
Old Nov 20, 2008 | 09:20 PM
ReAX's Avatar
ReAX
It depends on the the transmission. His is either 0.74:1 (4r100) or 0.70:1ish (5r110), with 35" tires 60mph is right at engine 2000rpms. With stockers the engine rpms go up only a little for 33s and a bit more for 31s. Your looking at 2700rpms for 70mph, and that's tighter than I want to keep an engine at for long lengths of time.
Old Nov 21, 2008 | 04:12 AM
Monsta's Avatar
Monsta
Sit. Stay.
FWIW, the 4R100 & the 5R110 have the same OD ratio of .71.
Having just regeared to 4.30's when I put on my 20's I can say, equivocally, that they are a perfect ratio. My tires are slightly taller than stockers and I still sometimes feel that it could use a lower OD. I know I'd be really frustated if I had 4.56's given the amount of torque the V10 makes (especially compared to the Hemi Durango)
Acceleration is much improved! Although I have no empirical data to back that up.
Old Nov 21, 2008 | 08:39 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
But you do have a BSEG
Old Nov 21, 2008 | 01:37 PM
nebmike's Avatar
nebmike
She's gone on to another happy home, but I had an '05 V-10 Excursion that I used to tow a 30' travel trailer quite regularly in the Colorado mountains. I was looking for more power and had tried several options, including a couple different programmers and ultimately a full Banks Powerpack (headers and all). None of it really made much of a difference -- and certainly not a difference that was worth the expense.
As a last ditch to gain the power I wanted, I swapped my 3.73's for a set of 4.56's and it was, without question, THE BEST decision I made with regard to increasing performance. I was running 33's, and the combination made for one hell of a towing rig.
Unloaded, on the open highway, the 4.56's obviously caused higher RPM's, but I only dropped about .5 mpg on average. While towing though, I actually increased 1-2mpg.
If I had it to do all over again I would have skipped the programmers and the Banks stuff and just went with the gear swap -- and I'd be $$$$ ahead!
Old Nov 21, 2008 | 01:38 PM
Monsta's Avatar
Monsta
Sit. Stay.
Yes. Yes , I do! Thank you very much (again)!
khadma
6.4L Power Stroke Diesel
Jul 25, 2008 08:59 PM
jimwilsonmasonry
May 13, 2008 08:32 PM
rush2112
Nov 13, 2006 09:23 PM
skycarpslayer
Mar 4, 2003 07:08 PM
BigJake86
Aug 11, 2001 01:19 AM
