Sponsored by: Auxito
E4OD issue
Old Nov 19, 2008 | 05:53 PM
galaxie641's Avatar
galaxie641
E4OD issue
Alright my E4OD is slipping out of gear as far as I can tell. When lightly hitting the gas, especially when slowing down or going down hills, I fell it bucking for lack of a better term. The scan gauge says the engine RPM's are not changing nor does my tach. It will do it in both 3rd and 4th and might be worse when locked in 3rd. The engine and tranny have around 230K miles on them and the fluid in the tranny looks and smells fine and has around 20K miles on it with a 24qt mag hytec pan. Whenever it does this if I give it gas it stops, but when I am driving around 40mph in 4th it does it a lot since there is usually very little gas need to keep the truck moving at that speed in that gear. Acceleration is fine and it will also do this with the cruise on when going down hills and it may be worse when cold. Any ideas would be great.
Also if the truck coasts without hitting the gas at all it does NOT do it. To me it seems like the torque converter isn't transfering the power correctly under light throttle but I am not aq tranny specialist.
Old Nov 19, 2008 | 06:19 PM
n3up's Avatar
n3up
Almost sounds to me like the classic torque converter clutch shudder.
With that many miles on it, the TC clutch is probably shot.
You could probably just change the converter, but with that many miles, I'd just have it rebuilt while it's out.....
Old Nov 19, 2008 | 07:32 PM
galaxie641's Avatar
galaxie641
I was wondering if it was shudder, always heard it referred to as driving over speed bumps which I suppose you could say this feels like at times.
BDFD
18
Mar 26, 2021 12:42 PM
ErrorS
Jan 11, 2011 10:59 AM
subford
Nov 13, 2010 05:42 AM
Ecko_brain18
Dec 4, 2004 11:09 AM
SirDino
Jun 15, 2003 10:25 PM
