Help with the lingo
Old Nov 19, 2008 | 04:00 PM
doubleman's Avatar
doubleman
Help with the lingo
Okay guys go ahead and laugh...new guy on the block and need to be updated on abbrevations you guys use for things. IDM, IPR, PCM, 15*, 17*, CEL, PMS, SD body, LD body,
Powerstroke SRW, FPR . I think the last one is fuel pressure regulator, but the rest I'm not sure about. Also liked the idea all you guys have on the 6637 air filter, I'm using the stock box with a K&N filter (not good I hear, explain problems with box), but doesn't that 6637 filter get wet. Your not afraid of the paper getting weak from moisture and sucking a hole in it. Thanks in advance for all you guys knowledge.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Darron
’96 F350 PSD, 2wd
Ext.cab dually
“Stone Stock”
Auto trans.
4:10 rear
94k miles
Old Nov 19, 2008 | 04:21 PM
tjbeggs's Avatar
tjbeggs
fficeffice" /><o>></o>>
Darron
’96 F350 PSD, 2wd
Ext.cab dually
“Stone Stock”
Auto trans.
4:10 rear
94k miles
This is not a laughing matter!
IDM-injector driver module
IPR- Injection pressure regulator
PCM-powertrain control module (computer)
15*- 15 degree HPOP ( stock high pressure oil pump)
17*- same as above but 17 degree so higher capacity, stock on 99-03 superduties
CEL- Check engine light
PMS-Powerstroke modification syndrome (careful its very contagious)
SD body- superduty body- started in 99 to current ford trucks
LD body- light duty 97 and up f-150's
Powerstroke SRW- single rear wheel
FPR
-fuel pressure regulator
Here is a full list that will help you
Tips - Idea - Hints
lots of good info there
On the filters the stock box no matter what filter is there doesn't seal well so it allows dirt in. K+N itself allows dirt through the filter media.
The 6637 doesn't get. Never had mine wet except when I wash the engine bay and forget to cover it
Old Nov 19, 2008 | 07:02 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Everything that TJ said and Welcome Aboard. Nobody laughs at real questions posted on here, we're to help each other so ask away and fell free to use the search function because alot of questions have been asked and answered repeatedly.
Old Nov 19, 2008 | 07:53 PM
helifixer's Avatar
helifixer
I have hit mi 6637 with the pressure washer and it didn't even distort it. I however don't recommend pressure washing them! I do blow through puddles (on the occasion that it actually rains here is Arizona) and have never had a problem. I had 50,000 miles on my old one when I changed it and there was no power difference with the new one, so it still had useful life left in it. and no turbo dusting.
Old Nov 19, 2008 | 07:57 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i have hit very deep puddles with mine with no problems.... as for washing it, ask tj about the walmart mod.....
Old Nov 19, 2008 | 08:19 PM
tjbeggs's Avatar
tjbeggs
Old Nov 19, 2008 | 08:47 PM
952X4's Avatar
952X4
The Wal-mart mod?? Come on TJ, let's hear it...
Old Nov 19, 2008 | 08:57 PM
tjbeggs's Avatar
tjbeggs
The walmart bag is simple. To get a clean engine bay it needs to be washed well and frequently. So to keep water off the 6637 I simply put a walmart bag over the filter and wash vigorously. The mod part comes when you forget to remove the bag, close the hood and drive into town to get some lunch. The truck actually performed flawlessly!
In all truthfulness though the time I actually did this its wasn't a walmart bag it was a plastic seat cover we use at the shop to keep customers seats clean. So only most of the filter was covered. One of these days I will get a picture of the Walmart bag mod!
Old Nov 19, 2008 | 09:02 PM
952X4's Avatar
952X4
Good idea on the bag to keep the filter dry....Love the mod part.....
Old Nov 19, 2008 | 11:18 PM
Eric_F250's Avatar
Eric_F250
good question and good on you for asking it. if this community is one thing, it's helpful beyond description. never hesitate to ask. revisiting well trodden topics always bring some new tidbit out of the woodwork.
-e
ps- here's an semi-useful piece of info... hit 2, then 4, then 8 on your number pad while holding down the "alt" key to get the "degree" symbol. it'll make all your friends think you are a computer genius! (i.e. "use the 203° thermostat")
Old Nov 20, 2008 | 08:46 AM
Neal 97 250's Avatar
Neal 97 250
Eric that is cool. Got any more tips?
Old Nov 20, 2008 | 09:57 AM
TexasDiesel97's Avatar
TexasDiesel97
On the note of learning the lingo, can someone tell me what IIRC means?
Old Nov 20, 2008 | 10:03 AM
plowhand's Avatar
plowhand
Playing in the Dirt
IIRC = If I Remember Correctly
Old Nov 20, 2008 | 10:15 AM
Neal 97 250
I believe Steve Baz has some on his website.
Oops that is what Tim linked
IMO. In My Opinion
LOL. Laughing Out Loud
LMAO. Laughing my a-- off
ROTFLMAO. Rolling on the floor LMAO
OBS. Old Body Style, '92-'97
Just a few more useless lingo tips.
Old Nov 20, 2008 | 11:19 AM
doubleman's Avatar
doubleman
Thanks for all the help guys, going to do the 6637 filter mod this weekend, time for service anyways. Also going to change thermostat to 203°(symbol's cool Eric) noticed it taking to long to warm up lately, old one must be stuck open some, it's the original. Been changing antifreeze every 3 years since truck was new and using John Deere Cool Guard already mixed 50/50 and has DSA additive already in it. (anyone know anything bad on it) I worked for Ford Ag. dealership for 17 yrs. and John Deere 5 yrs., always been a little gun shy of electrolysis happening in diesel engines. Going to replace the CPS (thanks TJ for link) also, it's the original one, but truck has been cutting off on it's own lately and hicupping go down the road, thought I had a short until I found this site.
Many "Thanks" again to all of you!!
Darron
’96 F350 PSD, 2wd
Ext.cab dually
“Stone Stock”
Auto trans.
4:10 rear
94k miles
