sway bar bushing install
Old Nov 19, 2008 | 06:37 AM
hdman6's Avatar
hdman6
Question sway bar bushing install
I just ordered my sway bar bushings from energy suspension. I need to replace the front and rear. So I pretty much figured out the drop links. But the bushings that go on the sway bar itself, are they easy to slip on? I was thinking of wd 40 on the bar or something to slide it on easy. Also I have to replace the rear as well. I read that I dont need to jack up the truck correct? Hopefully this will be a easy job and cure my clunk clunk. I just finished replaceing both front hub assemblys this month, so this will be the last repair (for now) and get me through the winter. Thanks Jeff M.
Old Nov 19, 2008 | 06:58 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Hey Jeff. I didn't install new bushings, but I did install new link ends. Just bolt them up, don't have to do any jacking. I would also change the two bushings on the swaybar itself. They were 17.00 each at the dealer. .
Good luck.
Old Nov 19, 2008 | 07:20 AM
vettdvr's Avatar
vettdvr
The sway bar bushings normally have a slit in them. You just remove the bushing holder and loosen the second holder. Then with the cap off you can remove the rubber bushing with the slit. I normally use silicon lubricant during reinstallation. Normally you don't have to remove the end links.
I have not done this on my truck but have on many other cars.
Old Nov 19, 2008 | 09:18 AM
SuperDoodie's Avatar
SuperDoodie
I had to use a press to get mine out.
Old Nov 19, 2008 | 09:46 AM
vettdvr's Avatar
vettdvr
You must be talking about the end links. I am referring to the sway bar bushings not end links.
AllaboutMPG
Aug 12, 2014 09:32 PM
HH60FE
18
Jun 3, 2013 10:42 AM
allhuntalltime
Feb 21, 2013 10:20 AM
hdman6
Nov 27, 2008 12:53 AM
jhoward
Dec 19, 2006 02:45 AM
