Dreaded Clunk in front end
Old Nov 28, 2012 | 09:36 AM
HH60FE's Avatar
HH60FE
4 Years ago I replaced all sway bar bushings with the energy suspension ones. Got the clunk back on drivers side. Does this mean I need to replace them already or just loosen and retorque everything. Thanks.
Old Nov 28, 2012 | 10:39 AM
F250_'s Avatar
F250_
It doesn't cost anything to loosen and retorque, and you might just find your answer in that effort.
Don't forget, the clunk could also be ball joints, but is probably not tie-rods.
Old Nov 28, 2012 | 04:39 PM
HH60FE's Avatar
HH60FE
I was gona give that a try this weekend, just wondered if anyone had changed their bushings and to replace them after such a short period. Thanks.
Old Nov 28, 2012 | 04:43 PM
husker's Avatar
husker
I've also gotten the clunk from a sticking caliper pin.
Old Nov 28, 2012 | 06:17 PM
bkuuz1's Avatar
bkuuz1
Mine, turned out to be a bad shock. Now I'm thinking about ditching the the Ranchos and going with Bilsteins.
Old Nov 28, 2012 | 07:57 PM
sudsmcduff's Avatar
sudsmcduff
i have same problem for years, i just replaced all front end parts except leaf spring bushings, so guess that is the clunk.
Old Nov 29, 2012 | 11:05 AM
HH60FE's Avatar
HH60FE
I'll post back up after this weekend's retorque to let ya'll know if that fixed/helped.
Old Nov 29, 2012 | 12:35 PM
F250_'s Avatar
F250_
Forgive the hijack....
Not satisfied with the Ranchos? Which ones are you running? I've been running Bilsteins for 3-1/2 years and am considering going with the Rancho 9000XL series.
I've also seen a thread or two mentioning unacceptable customer service from Bilstein on warranty issues.
Old Nov 29, 2012 | 12:52 PM
kupaa's Avatar
kupaa
My bilstiens went out in less then two years.
Old Nov 29, 2012 | 04:52 PM
Feonix1123's Avatar
Feonix1123
I have a clunk come n go too i find it every time its the stupid sway bar link have had my shop tighten that bolt 4 times now im about to find a damn welder and somehow weld the damn thing shut.... Its on the driver side some how it keeps coming loose. its not the upper/lower ball joints or the tie-rod ends they are less then a yr old. all moog parts. Any idea WHY guys
Old Nov 30, 2012 | 08:54 AM
F250_'s Avatar
F250_
Could be vibration related loosening of the bolts, BIG GUY. I would suggest using some blue loctite and see if that keeps things in place for you. Whatever you do, do NOT use the red loctite! Use BLUE.
Old Nov 30, 2012 | 09:07 AM
Feonix1123's Avatar
Feonix1123
Okay thanks man But im telling you its getting old and the shop even used a lock nut this last time. It holds for a few months then it must get loose again so weird but its one of those KNOCKS im getting used too. Every time i go back i tell them to tighten that damn nut again. Could it be cheap Bushings? i bought them at advance auto last yr..
Its that stupid top bolt on the fame holding the sway bar link on the front driver side.
RED sure why not LMAO thats like Welding it right? lol
Old Nov 30, 2012 | 10:37 PM
StrokedRanchero's Avatar
StrokedRanchero
My clunk at the moment seems to be the center link. I changed my end links a yr. ago, clunk went away. The same kinda sound came back. I did an oil change the other nite, & upon checking everything found the new source to be the center link. '99 F250 CC, 2WD.
Old Dec 3, 2012 | 09:57 AM
HH60FE's Avatar
HH60FE
Update: Loosened all 4 bolts and retorqued. So far no clunk.
Old Dec 3, 2012 | 10:02 AM
F250_'s Avatar
F250_
Hope it holds up for you, Matt.
