Cab Swap
Old Nov 18, 2008 | 11:36 PM
BC Ford's Avatar
BC Ford
Cab Swap
Hello I have been lurking for several months and am now ready to seek advice! I have a '76 F250 Regular Cab 8' box Camper Special, 2wd, 460, AT, I bought the truck from the original owner with 157,000 miles on it.
Overall body condition is excellent, frame is rust free and straight, mechanically almost perfect. My preference is to have a super cab short box so my questions are;
Can I swap the cab from a '76 super cab and mount it easily on my frame or were the frames different?
If I do swap cabs can I swap my 8' box for a 6' and have it all fit?
Thanks in advance,
James
Old Nov 18, 2008 | 11:54 PM
cipsmithers's Avatar
cipsmithers
Im not sure about doing this with a super cab but I know it wont work with a crew cab. The wheelbases are slightly different.
Old Nov 19, 2008 | 07:27 AM
caspermj's Avatar
caspermj
bump curious myself!
Old Nov 19, 2008 | 01:18 PM
jumbofordman's Avatar
jumbofordman
I looked at doing this at one time (found a deal on a SuperCab, but it turned out to be a rust bucket when I went to look at it.) Anyway, I did some looking at the frame and the rear cab mounts are in different locations (farther back) on the SuperCab. So I have the feeling the frames are different enough to make this more than a simple pull and replace type deal.
Old Nov 19, 2008 | 01:43 PM
Duke78's Avatar
Duke78
Even if the frames are different the rear cab mounts are located on a crossmember so would it be possible to cut the rivets and move the cross member farther back? My assumption is that the super cab has 4 cab mounts like the regular cab. Just a thought.
Old Feb 17, 2009 | 01:16 PM
junkman 11's Avatar
junkman 11
Thanks in advance,
James
James, i am curious if you have made any headway on this project. I was considering doing the same ad any info would be great.
Lorne
Old Feb 17, 2009 | 02:39 PM
Alvin in AZ's Avatar
Alvin in AZ
Heck no, the frames aren't the same! :/
Them's Fords ain't they? LOL :)
I've got two '75's... F100SC 155" and F150 133".
The F100SC's frame is "taller" than the F150's.
They added a "belly" to it, to gain strength looks like.
I don't know where to go from here, I'll need specific questions, and some
measurements would be a big help to go with them. I could then compare
yours to mine... or something like that?
"Ford never learned how to make the same part twice ;)" -my Chevy buddies
Alvin in AZ
ps- You know, you guys need to edit your information so a guy won't have to
switch pages just to look up where you are. If you edit it one time it'll save a
hundred readers from having to look it up ...make sense to you?
pps- I have an Arizona "city" truck's SC-cab I don't want.
James 007
Feb 14, 2010 02:16 PM
F700 Pickup_man
Oct 19, 2007 03:11 PM
76hi-boy
Mar 27, 2005 09:22 AM
blueoval429
Dec 14, 2004 02:40 PM
FamilyTruckster
Apr 7, 2000 08:15 AM
