2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Tire Psi Light
Old 11-18-2008, 10:33 PM
SCHOO79's Avatar
SCHOO79
SCHOO79 is offline
Tire Psi Light
We had a flat tire on a trip and had replaced but they could not get the warning light on the dash to go away. Is there a way to turn the light off?
Old 11-19-2008, 10:32 AM
berry1234's Avatar
berry1234
berry1234 is offline
Is the PSI correct on the replaced tire? If so it should reset itself after a few miles. If not, the sensor may have gotten damaged. Check the psi on all of the tires.
Old 11-20-2008, 11:50 AM
shorebird's Avatar
shorebird
shorebird is offline
Old 11-20-2008, 11:55 AM
berry1234's Avatar
berry1234
Originally Posted by shorebird
You need the tool on the right; New compact TPMS tool from Ford - Corral Forums
No, you don't need to buy anything. If your car is under warranty take it to the dealer once you have confirmed all the tires have correct psi. It should reset itself.
Old 11-22-2008, 08:04 PM
SCHOO79's Avatar
SCHOO79
SCHOO79 is offline
thank all, i called the dealer and he said it would a 50$ just to look at it but the work would be free. i was just wishing it was a easy fix.
Old 11-23-2008, 10:39 AM
berry1234's Avatar
berry1234
How many miles on your truck? Whoa. What dealer charges anything to fix warranty related items?
Old 11-23-2008, 01:07 PM
SCHOO79's Avatar
SCHOO79
SCHOO79 is offline
about 33,000 miles. That what he said over the phone that why i am asking you all first.
Old 11-24-2008, 11:18 AM
berry1234's Avatar
berry1234
You have 3,000 miles more until your warranty expires. Do not pay for a diagnoses. Diagnosing and repairs under warranty cost zero. Find another dealer. It's a no brainer.
Old 12-15-2008, 08:47 PM
SCHOO79's Avatar
SCHOO79
SCHOO79 is offline
If anybody wants to know, the warranty covers the sensor as a whole, not as pieces. There is a unique way to remove the tire from the rim. If you don't know this you will destroy the sensor and will not be covered under warranty.
and the spare tire does not have the sensor in the tire ether.
Old 12-15-2008, 10:49 PM
benshere's Avatar
benshere
benshere is offline
sensors
I was surfing the truck accessories sites a while back and saw and ad for tire sensors that did not require a band. It was all apparently inner part of the stem. Wondered if it causes any balancing problems and lots of offsetting weights. Dont know if it was for fords or not, guess I better try to find it again.
Old 12-16-2008, 10:52 AM
berry1234's Avatar
berry1234
Well any good tire shop or mechanic knows that almost all of the newer cars have these and they shouldn't be damaging them. If they do, they should pay for a new one.
Old 12-21-2008, 09:00 AM
blackout150's Avatar
blackout150
blackout150 is offline
the tpms Ford is using is crap compared to the rental cars I have used (Honda Civic and Chevy Cobalt). On those two cars you can toggle through all the different monitors (temp, oil life, etc) and it shows the psi for each individual tire. On my 08 Expy, unless I am missing something, I cant find it anywhere. Of course when I got a Tire pressure monitor error, I had to call the dealer and they asked if the tire pressure is ok, then they said it just needed to be reset. My first question is, what caused the error? unknown. I think they could have come up with a better system.
Old 12-21-2008, 08:27 PM
shorebird's Avatar
shorebird
The reset tool comes with the '08 F-150. I had to point out to the dealer where in the manual it stated that it was to be with the vehicle. Check your owners manual in the section concerning the TPMS as to whether it should have been with yours. Pics of the tool;
ddawsey
New Member Introductions
01-29-2016 09:55 AM
mebe2k
6.7L Power Stroke Diesel
33
11-15-2015 10:56 AM
stv1991
1999 to 2016 Super Duty
06-21-2015 03:07 PM
BrookPE
1997-2006 Expedition & Navigator
03-16-2012 05:06 PM
Alligator06
08-18-2011 09:22 PM
Quick Reply: Tire Psi Light
