Lope Idle?
Old Nov 18, 2008 | 09:42 PM
JethroF250's Avatar
JethroF250
Question Lope Idle?
I havent plugged my truck in yet this year and its doin great. Went to start it this evening after sittin for 6 hours in 20* weather with wind. She fired up and was really cold but notuced it had a hard lope idle for about 10 sec. Is this normal for the mods I have?
Old Nov 18, 2008 | 10:17 PM
IDMooseMan's Avatar
IDMooseMan
I'm not as familiar with EOT mod as the others, but as I understand it, the EOT mod tricks the PCM into thinking the oil temp is colder than it actually is.
With 20* weather and the EOT mod, the PCM might not be able to compensate for what it "thinks" the engine oil temp is.
Try disconnecting the EOT mod when you get home. Let her sit for the six hours or whatever and see how she acts when you try to start her. If the lope is gone, I'd bet the EOT is the "issue". You could try rigging a bypass switch for the colder months. Once she's warmed up, flip the switch.
Old Nov 18, 2008 | 10:25 PM
JethroF250's Avatar
JethroF250
Good idea. My only question now is the eot is only 4.7k. Joe was explaining to me about how the engine can go down to a rediculous number. I think in the negative range. It may be possible that the PCM thinks it is this low but I was wandering if it could be the 20k as well since I'm sending more fuel to it while its still cold. I guess this one will be a mystery until I figure out exactly what it is. Kinda made me feel special though. Not only did I smoke out my friends house but I also sounded like a mod care at the strip
Old Nov 18, 2008 | 10:52 PM
IDMooseMan's Avatar
IDMooseMan
I should have checked for your mods before replying but, some guys have problems with the HPOP and the higher resistor combinations. With some resistors (mid- to high-20s) the HPOP can't compensate.
Others run 22K+ resistors but have the 17* HPOP and everything works great. Each truck is different. My truck was ok with a 20.3K resistor but crapped out with a 25k. I have the stock HPOP.
Old Nov 18, 2008 | 11:31 PM
97biostroke's Avatar
97biostroke
I've ran up to 30k resistance on a basically stock truck ( except for breathing mods ) without getting a lope or running codes or running out of oil capacity. But after about 20k I'm pretty sure the power was decreasing, so i just keep it at 15.6 now. Just goes to show they're all different
Old Nov 19, 2008 | 06:43 AM
tjbeggs's Avatar
tjbeggs
It sounds like the cold weather romps to me. Its nature of the beast with our injection system. The cure is block heater or thinner oil (5W40, 10W30)
Old Nov 19, 2008 | 08:16 AM
JethroF250's Avatar
JethroF250
will the thinner oil hurt? my truck runs amazing with 20k and no CEL. i like the lope, just shows the beatlyness of our trucks lol, but want to fix it before somethin gets messed up if it can be messed up
Old Nov 19, 2008 | 08:44 AM
tjbeggs's Avatar
tjbeggs
5w40 oil will be fine. Some run Diesel rated 10w30 as well but the 5w40 diesel rated oil will be just fine.
Old Nov 19, 2008 | 09:11 AM
MADVAN's Avatar
MADVAN
Will add a test with starting in neutral.
WAG is the EOT thing. Cropduster
5/30 user.
Bill
Old Nov 19, 2008 | 07:32 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i have the scanner handy, i will give you the exact change between stock and the 4.7k in the eot sensor.....
Old Nov 19, 2008 | 07:46 PM
MADVAN's Avatar
MADVAN
K Ohms__Volts____TempF___Temp C
826______4.75______-32______-36
785______4.75______-30______-34
575______4.73______-22______-30
525______4.72______-20______-29
365______4.68______-10______-23
300______4.65______-4_______-20
250______4.63______0________-18
192______4.6_______10_______-12
173______4.55______14_______-10
139______4.49______20_______-7
103______4.4_______30_______-1
98_______4.38______32_______0
64_______4.18______40_______4
59_______4.13______50_______10
43_______3.92______60_______16
37.3_____3.8_______68_______20
33.6_____3.73______70_______21
26.8_____3.53______80_______27
24.3_____3.44______86_______30
21.5_____3.32______90_______32
17.2_____3.08______100______38
16.1_____3.01______104______40
13.9_____2.84______110______43
11.2_____2.59______120______49
10.9_____2.56______122______50
9.34_____2.38______130______54
7.55_____2.11______140______60
6.28_____1.89______150______66
5.34_____1.72_ _____158______70
5.32_____1.71______160______71
4.48_____1.52______170______77
3.84_____1.37______176______80
3.75_____1.35______180______82
3.17_____1.18______190______88
2.8______1.09______194______90
2.68_____1.04______200______93
2.2______0.88______210______99
2.08_____0.86______212______100
1.87_____0.78______220______104
1.56_____0.67______230______110
1.33_____0.59______240______116
1.19_____0.53______248______120
Resistance is not linier across the range of the sensor
Bill
Old Nov 19, 2008 | 07:51 PM
c00nhunterjoe
holy crap! how long did it take you to make that?!
i dont think you followed what i meant, i am going to hook the scanner up to see how many degrees the 4.7k drops the oil temp reading.
Old Nov 19, 2008 | 08:03 PM
MADVAN's Avatar
MADVAN
Cut and paste Joe.
Look at the chart and add 4.7 at 200*.
Then look at the 4.7 added at 32*.
You will see what i mean.
Bill
Old Nov 19, 2008 | 08:06 PM
WALJON's Avatar
WALJON
I am trying to understand this mod ,does it advance the timing or retard the timing?
Old Nov 19, 2008 | 08:09 PM
tjbeggs's Avatar
tjbeggs
nobody knows..........
