Crrank shaft Question
ffice
ffice" /><o
></o
>I got the crank by swapping my old 360 crank with my machinist's shelf stock. <o
></o
>All the resizing and machining is done so here’s my problem.<o
></o
>While assembling the crank, rods, and pistons I found the front bolt on the crank was the incorrect length because when I tried to back it out it damaged the internal threads. There was galling on the bolt and when I chased the internals there was some damage there too.<o
></o
>I Dare not run the new correct bolt into the hole as I'm sure it would be screwed up too. Basically I don't trust torking on them to turn the engine by hand. <o
></o
>The thread size is 5/8 x 18.<o
></o
>The wrong bolt was 2 inches the correct bolt is 1 3/4 long. The factory pilot hole in the crank is 2 1/2 inches deep. Where as the threads only go the 1 3/4 inches. <o
></o
>So is my crank shot? <o
></o
>If not what size threads can I re-cut to safely and have strong new threads?<o
></o
>OR <o
></o
>Do I need to just take it back to the machinist?<o
></o
><o
></o
>Thanks <o
></o
>John
N try n loose the excess pink smileys..lol its distracting
Thanks though I will repost under the FE forum.
John
PS. I didn't insert any smiles when I wrote it. The arrows popped up after I submited the post.
