Coolant flush
Old Nov 18, 2008 | 09:58 AM
JIM_C's Avatar
JIM_C
Coolant flush
Dropped the lower radiator hose and got about 3 gallons out each time. Replaced with distilled water, drive around the block a couple times until the gauge read normal, repeat. Used 13 gallons of water and it was draining clear and other than having to go buy a new hose clamp to replace the POS stock clamp, went well. Put in 3 gallons of Motorcraft Gold at the end and the fluid is about an inch below the MIN line in the degas bottle. I'll keep an eye on it and may add another half gallon of coolant if it drops any. The manual said 28 quart capacity so 3 gallons of coolant is pert near 50%.
Old Nov 18, 2008 | 12:31 PM
69cj's Avatar
69cj
Sounds good to me. I would try for another qt. of coolant if it won't take you over the min. mark.
kbarbee95
Dec 9, 2014 02:44 PM
whiteboyslo
16
Mar 9, 2014 12:42 AM
Eallend7
Apr 28, 2013 07:49 AM
rjwood5
Mar 17, 2013 05:24 PM
2danglong
Jun 8, 2005 09:24 AM
