Coolant not circulating?
Old Dec 9, 2014 | 11:16 AM
kbarbee95's Avatar
kbarbee95
I have a 99 f350 xlt 4x4 and I just replaced the waterpump and did a coolant change. I dropped the lower radiator hose and drained out everything through there as much as possible my question is that I poured in 4 gallons of concentrate but I only managed to add about one gallon of water and now the water doesnt seem to have circulated at all yet and I have been driving it for about a day and a half now. Temp gauge marks normal and when I squeeze the top radiator hose coolant flows back into the degas bottle from the bottom hose. Degas bottle still marks full from initial fill up. AND If I have the short thermostat instead of long what would happen? Would that cause no flow of coolant?
Old Dec 9, 2014 | 12:24 PM
kbarbee95's Avatar
kbarbee95
And also the upper radiator hose is was hot but not the liquid in the bottle
Old Dec 9, 2014 | 01:53 PM
jasonc76's Avatar
jasonc76
Wrong thermostat or stuck thermostat.
Old Dec 9, 2014 | 02:44 PM
SARDiverDan's Avatar
SARDiverDan
Additionally, you may be running a 70/30 ratio or higher. Figure you have 4 gallons of concentrate, one gallon of water, and 3 gallons of whatever you had previously. Might want to measure the fluid and see where it's at. While you might get away with a 60/40 ratio in colder areas, I would guess your coolant to water ratio is way too high.
Garrett Killgore
18
Nov 5, 2016 11:42 AM
Natcox012
Jan 24, 2015 08:47 AM
LRMetric
Sep 26, 2012 09:51 AM
JIM_C
Nov 18, 2008 12:31 PM
dboys3021
Sep 8, 2006 05:30 PM
