What size "blocks" should be on a 2001 F250 SD 4x4?
My trucks rear sits lower than the front- I looked at the blocks last night and they look to be 2". Is that stock?
If not- Can I swap out myself???
What is involved.?? Will Ford do it?
That truck may have sway bars, but I doubt it has torsion bars, since it is 4x4 it has leaf springs at all four corners. As for sitting lower in the rear I would have Ford check that on that new of a truck something is not right. All 4x4 SD that I have seen sit 2-3" higher in back than the front when empty.
haha my bad i thought you said your front sits lower than the back, naw you have no torsion bars, you can go with blocks in the back and that will raise it up :-X11
