2005 died
Old Nov 17, 2008 | 08:53 PM
JFRED's Avatar
JFRED
2005 died
I have a 2005 with 6.0, 72,000m, all of a sudden started running rough and died. Started back up once, then died. Now will turn over strong but will not start.
Replaced fuel filters(both) checked and seems to have good fuel pressure and fuel at 2 of the 4 tubes.
Replaced the cam position sensor , since this was the problem on 3 past Fords.
Turns strong, but no start.
Old Nov 18, 2008 | 06:51 AM
ljutic ss's Avatar
ljutic ss
Sounds like your truck is still under warranty, have it towed to a Ford dealer and let them worry about it.
Old Nov 18, 2008 | 06:53 AM
FTX's Avatar
FTX
Read this article...
Diesel Technician Society
Old Nov 18, 2008 | 06:55 AM
bismic's Avatar
bismic
Have you checked for DTC's (diagnostic trouble codes)? They will help narrow it down. The most common "no start" condition is when the High Pressure Oil Pump" system develops a leak at the "snap-to-connect" fitting. However, this is usually characterized by a no-start when hot.
It can be several other things though - so check for DTC's if you haven't.
Just curious - are you using OEM or OEM style oil and fuel filters and have you load tested the batteries? I know you said it cranks strong, but I always load check the batteries first thing on a no-start - just to be sure.
Old Nov 18, 2008 | 08:31 AM
yz400f's Avatar
yz400f
I have an 05 scurge and it was doing the same thing. Almost start...... Spinning faster than just the starter motor....... but just would not catch fire. It was the EGR valve stuck open a little. Deluted the intake air with burnt gas just enough to not start. Like someone said. Pay the 100.00 and let them fix it.
Oh, I forgot, I had no codes at all.
Old Nov 18, 2008 | 08:42 AM
LSchicago2's Avatar
LSchicago2
My 05 did that twice, first time was the HPOP, second was a pin hole on the IPR. So many problems with mine, that I finally accepted defeat. My truck has since entered the afterlife, and has been Zombie limping around waiting for it's V10 replacement to send it to 6.0 heaven!
