No start after injector install, Need help.....
Old Nov 17, 2008 | 10:20 PM
matt71's Avatar
matt71
Also, I forgot to mention as im cranking it and the batteries start losing juice, the CEL comes on. Is this normal?
Old Nov 17, 2008 | 10:23 PM
RubberDuck's Avatar
RubberDuck
Then I would rule out the gear and fuel. Time to get back under the VC's. Any way you could do a buzz check?
Old Nov 17, 2008 | 10:24 PM
RubberDuck's Avatar
RubberDuck
Man, I'd get a full charge on those batts, or maybe replace them. CEL means code....that could help.
Old Nov 17, 2008 | 10:32 PM
rockitdog's Avatar
rockitdog
Rubber Duck has a good point, get those batteries charged and try again tomrrow with a buzz check. BTW I am pretty sure oil wont come out of the holes on the injectors unless the injector is getting a signal to fire.
Old Nov 17, 2008 | 10:45 PM
RubberDuck's Avatar
RubberDuck
All the more reason to check it right?
Old Nov 17, 2008 | 11:17 PM
rockitdog's Avatar
rockitdog
exactly, could help find where the problem lies!
Old Nov 18, 2008 | 02:25 AM
matt71's Avatar
matt71
I have no way to do a buzz test. I dont know anyone with a scanner to do it with.
Old Nov 18, 2008 | 08:22 AM
wmiller's Avatar
wmiller
I know it sounds really dumb but did you crack the lid on the fuel bowl to get the air out. I had this problem when i put my 2s in. It didn't want to bleed on its own
If you still have the vc undone try unplugging the injectors and check for power and work your way back toward the outside of the cover.
Also does your wait to start light come on then you turn the key?
I would also plug it in for a couple hours before you try and start. Always makes things easier when everything is warmed up
Old Nov 18, 2008 | 10:09 AM
matt71's Avatar
matt71
It seems to me like there isnt any fuel getting into the cylinders. Would I have to crack the fuel lines open to get the air out maybe? When im cranking it over im not getting any kind of smoke from the exhaust at alll.
Old Nov 18, 2008 | 04:22 PM
WALJON's Avatar
WALJON
x2 does your wait to start light come on?
Old Nov 18, 2008 | 09:05 PM
matt71's Avatar
matt71
I got it fixed guys. I found a little oil inside the IPR plug, i diried it out and then it was a matter of cranking and cranking and cranking. And by the way I love the stage 1's!! This site is great, you dont realize how helpful people are on here until you need the help. Thanks to all!
Old Nov 18, 2008 | 09:38 PM
RubberDuck's Avatar
RubberDuck
Glad you got it matt. Roll the coal!
karter81
Feb 26, 2016 02:23 PM
arkredneck
Dec 17, 2014 09:14 PM
278broncos
24
Mar 19, 2014 10:13 PM
superduty4x4
21
Mar 25, 2013 03:44 PM
amsk8er1983
Mar 12, 2013 10:02 AM
