Hard starts
Old Dec 17, 2014 | 04:08 PM
arkredneck's Avatar
arkredneck
Hard starts
I am pretty familiar with the 7.3 have had 5 or so of them. My 99 is having hard starts and its NOT glow plug related and its got good battery's and starter and all that. Can the injectors with lots of wear cause hard starts? Truck has 390k miles and its using a gallon of oil about every 500 miles. The oil is going into fuel system from injector orings I think. What kinda icp value should I get while cranking. Could it just be taking a while to build icp pressure. The problem is worse when cold but still happens with warm engine
Old Dec 17, 2014 | 05:11 PM
Pikachu's Avatar
Pikachu
The PCM won't send a fuel delivery command signal until ICP reaches 500 psi and RPMs are at least 100.
Old Dec 17, 2014 | 07:50 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
Worn injectors definitely cause hard starts, which mimic that of a problem in the glow plug system. Worn poppet valves and cold thick oil do not like each other.
Are those original injectors with 390K on them?!
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Dec 17, 2014 | 09:14 PM
arkredneck's Avatar
arkredneck
It looks like maybe 4 are iron orginal and 4 look like remans
88beast
Jan 26, 2014 12:08 PM
rockcrawler_101
Aug 4, 2012 07:06 AM
Christof13T
Jun 14, 2012 02:31 PM
4x4countryboy
Mar 26, 2012 05:57 AM
tap1946
Jan 17, 2012 07:33 PM
