going up
Old Nov 17, 2008 | 08:24 PM
crazymut's Avatar
crazymut
going up
I would like to get a little taller stance wiyh my truck. Wright now it is stock hight. I dont want to go tall just a little higher. Stock is just a tad boring. I am thinking 2 to 3 inches, any suggestions on lifts or anything else to get a little taller stance for my truck?
Old Nov 17, 2008 | 08:40 PM
That_Guy's Avatar
That_Guy
Icon make a 2in spring pack for the front and then you can get 350 rear blocks, they add 2in IIRC
Old Nov 17, 2008 | 08:49 PM
F350-6's Avatar
F350-6
If it were me, I'd contact Dan https://www.ford-trucks.com/forums/member.php?u=69368
He's a sponsor here, and with the support I've seen him give non-customers, I wouldn't have any problem spending money there. You'll never have to worry about the service behind the sale, plus he really knows his stuff.
Old Nov 18, 2008 | 06:01 PM
crazymut's Avatar
crazymut
Thanks for your responses. I will try to contact Dan.
Old Nov 18, 2008 | 07:39 PM
redfire42's Avatar
redfire42
Thats what I want to do, leveling the front with 350 rear blocks. Just waiting to find out what shocks to get.
Old Nov 18, 2008 | 10:02 PM
Tecman's Avatar
Tecman
This is what I did and it looks great! I went with bilstien shocks for 1-3 inch lift since I like the nickel plating as opposed to the yellow shock tube.
Old Nov 18, 2008 | 10:03 PM
Tecman's Avatar
Tecman
Also want to add, Dan is great, that is where I got my shocks from and was very helpful!!
Old Nov 18, 2008 | 10:11 PM
HKusp's Avatar
HKusp
I got this leveling kit and 4" blocks(from Superlifts) with new u-bolts for the rear.
eBay Motors: FORD F-250 F-350 SUPERDUTY DIESEL GAS SHACKLE LIFT KIT (item 330278146081 end time Nov-10-08 03:36:43 PST)
Old Nov 18, 2008 | 10:12 PM
Bigfwt04's Avatar
Bigfwt04
If you just want to go a little higher for cheap I have 2004 FX4 2" leafs and blocks that just came off my truck today that I can hook you up with. If you cover shipping and handling you can give them a try. You can run 35x12.50's and will barley rub at all. PM me if you want, could probably have them to you by this weekend.
Old Nov 18, 2008 | 10:57 PM
WA.Ranger's Avatar
WA.Ranger
I have a set of 6" rear blocks that were never used if you want them, just catch the shipping charge.
Old Nov 19, 2008 | 06:29 PM
redfire42's Avatar
redfire42
Looks good!!
What kind of angle are your drive shafts at now? What is the ride like, would it be any differnt then having a leveling leaf in?
Old Nov 19, 2008 | 06:54 PM
DCSpecial's Avatar
DCSpecial
Thanks.
Technically.....CAD Plated
7100s used to be nickel
Thanks.
Old Nov 19, 2008 | 07:15 PM
redfire42's Avatar
redfire42
I'll send ya a PM
Old Nov 19, 2008 | 08:01 PM
HKusp's Avatar
HKusp
Looks good!!
What kind of angle are your drive shafts at now? What is the ride like, would it be any different then having a leveling leaf in?
Not much different on the angles. No need to drop the drive shaft or change the pinion angle. The ride is not any different at all.
