302/C4 issue
Old Nov 17, 2008 | 05:37 PM
Frankenstang57's Avatar
Frankenstang57
302/C4 issue
Silly question for you guys. I'm putting a 302/C-4 combo in a buddies '66 Bronco. The motor is a 302 out of a '75 Bronco that had a manual trans. The C-4/D20 combo came out of another Bronco of a similar year. The trans came as a package deal off of Craigslist and included the converter, starter, t-case, flex plate, and the metal shim between trans and motor. When I get everything bolted together the motor won't turn over. I did engage the converter in the trans and it seems to be in as far as it will go. My question`is, did Ford change the back of the crank between M/T's and autos? Is there perhaps a different converter? Any suggestion or parts number will be appreciated! The Bronco was originally I-6 so I'm flying in the dark here. Thanx!~
Old Nov 17, 2008 | 07:39 PM
jk080's Avatar
jk080
Transmission Rebuilder
Does the converter pilot fit the crank shaft?
You should have to remove the pilot bearing for the standard transmission.
small.block.ford.guy
Nov 6, 2013 08:34 AM
ChaseTruck754
Dec 23, 2009 03:58 PM
helirich
1978 - 1996 Big Bronco
17
Jun 16, 2009 10:50 PM
Frankenstang57
1966 - 1977 Early Broncos
Nov 26, 2008 11:05 AM
Frankenstang57
Nov 18, 2008 05:05 AM
