Sponsored by: Auxito
MAF Sensor
Old Nov 11, 2008 | 03:35 PM
joe38socalif's Avatar
joe38socalif
MAF Sensor
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I have a 2000 ford F150 4.2L V6
I need to know what the 4 wires on the MAF Sensor are.
1. Red = POWER ?
2. Black = Ground ?
3. Blue = Sensor
4. Yellow = ecu ?
<o></o>
The above is only my GUESS does anyone know for SURE ?
Old Nov 12, 2008 | 12:42 AM
LxMan1's Avatar
LxMan1
It has two sensors in it, MAF for airflow and it also has a barometric pressure sensor. @ filaments. At least my 01 5.4L did.
I do not have a wiring diagram in front of me right now.
Old Nov 12, 2008 | 12:48 AM
joe38socalif
this is what I have found out
Pin 1: Not used
Pin 2: (Rd) Power (Hot in start or Run)
Pin 3: (Bk/Wh) Ground
Pin 4: (Tn/LB) MAF signal return
Pin 5: (LB/Rd) MAF signal out
Pin 6: Not used
and this is correct as i have checked it against my truck wires.
having said that pin number 4 i take it is the wire that sends back the infomation to the pcm ?
is that right ?
Old Nov 12, 2008 | 06:35 AM
projectSHO89's Avatar
projectSHO89
No, pin 5 is the signal output. Pin 4 is sig rtn, essentially ground.
BTW, the most common reason noobs ask for this info is so they can install their ebay resistor mod. If this is the case, throw it away 'cos you got scammed.
Steve
Old Nov 12, 2008 | 08:54 AM
Bobby82490's Avatar
Bobby82490
Yeah what do you need to know this stuff for.. if you dont mind me asking?
Old Nov 12, 2008 | 12:35 PM
projectSHO89
... I forgot to mention the other reason, that "MAF Enhancer" for the run-your-car-on water crap.....
Old Nov 12, 2008 | 02:45 PM
joe38socalif
Well thanks for the information, the sad part about this is that STEVE you’re so CLOSED minded that you can’t take the time to think if it is doable.I can tell you from personal experience after installing only the hho cell and no other mod’s it has taken my truck from 12 mpg up to 15.5 so that’s a 30 % gain, and no its not from paying attention to my driving, this has been an ongoing thing now for over 5 months. <o></o>
<o> </o>
For those of you who my live in the Florida area, ill pay for the gas it takes you to get to Orlando so I can take you on a test drive so you can see for yourself. If it works you pay for the round trip gas, if it doesn’t ill pay for the whole trip. <o></o>
<o></o>
Old Nov 13, 2008 | 06:33 AM
projectSHO89
Oh, puullleeeeesss.
Dude, go away. The HHO stupidity has been well debunked.
Old Nov 13, 2008 | 09:48 AM
joe38socalif
Think about it: Ignorance can be addressed through education but you can't fix stupid!......guess you are a total losssss ..l..
Old Nov 13, 2008 | 11:30 AM
KingRanchMan02's Avatar
KingRanchMan02
My truck is stock with the exception of the K&N air filter and the DiabloSport Predator tuner. Since February of this year to present day I have seen my mileage improve from 12 MPG to 17 MPG! Wait a minute, that has absolutely nothing to do with HHO injection and is better than your own results. How is that for debunking this nonsense?
Old Nov 13, 2008 | 12:07 PM
LxMan1's Avatar
LxMan1
Amazing John, no snake oil or anything?
Old Nov 13, 2008 | 12:20 PM
bowdog's Avatar
bowdog
Can't We All Just Get Along
Old Nov 13, 2008 | 01:27 PM
KingRanchMan02
Nope, just changed plugs this year, but I still have a occassional high load misfiring COP and I plan to replace the lot of them soon.
BTW, this is getting along!
Old Nov 13, 2008 | 03:50 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Nov 13, 2008 | 03:58 PM
KingRanchMan02
I was thinking about those when I saw your reply to someone else. I will definitely keep these in mind. Any further discounting available for FTE members?
Last edited by KingRanchMan02; Nov 13, 2008 at 04:03 PM. Reason: Added a question.
