Sponsored by: Auxito
Truck Dies
Old Nov 16, 2008 | 09:16 PM
Munch's Avatar
Munch
Truck Dies
I have a 1999 F150 4x4 w/4.6L auto. Once in a while while going down hills coasting the truck will die. It doesnt stumble, there are no codes, and it fires right back up like nothing happened. It idles at 600rpm and I knowtist that when it gear it idles rougher then when in park or neutral.
Old Nov 17, 2008 | 12:40 PM
KingRanchMan02's Avatar
KingRanchMan02
Could be a bad IAC valve or a vacuum leak. Good luck!
Old Nov 17, 2008 | 11:59 PM
jacobp_07's Avatar
jacobp_07
my 1997 f-150 with a 4.6 in it did something similar a while back. all mine ended up bein was that the throttle body was dirty. all i did was take the air intake tube off and then hold the butterfly open (with engine off) a take a rag soaked in throttle body or carb cleaner and clean out from around the butterfy seat. you might want to try this before you go and take it somewhere to get checked out.
Old Nov 18, 2008 | 03:49 PM
Munch's Avatar
Munch
Thanks for the help
2wilde4u
Mar 24, 2016 10:15 AM
Carmax
Sep 14, 2015 10:26 AM
MacPhly
Mar 18, 2015 08:06 AM
toofazt
13
Dec 16, 2012 09:09 AM
Mr Stacy A
2004 - 2008 F150
Aug 18, 2009 09:32 PM
