Which fuse for NO start.
Which fuses do you pull to not let the injectors fire to give the oil time to come up to pressure. I just did a motor swap in an early 99 and just like always, I'll pull fuse 22 and 9. And just like every time before, I crank on it, let rest, crank on it......etc for about 4 or 5 good cycles. Thinking the injectors aren't popping, I go for another cycle before replacing the fuses to let it try to fire, and what happens????? It starts! LOL Obviously I'm pulling the wrong fuses. Which ones do the trick?
It works good for long term parking too, just put it in the empty slot.
__________________
Rodney, can you expand on this? Do you call 2-3 Days Long term? And where is the IDM Relay. My truck has always started right off and ever sence the dealer changed the oil 2 weeks ago it has been a hard srart. Parked inside a heated garage, I now about glow plugs etc. just wondering if they put in to heavy an oil and if unpluging this relay may help. Thanks
