1978 - 1996 Big Bronco
6" lift
Old Dec 8, 2008 | 05:38 PM
Kemicalburns's Avatar
Kemicalburns
you can install a 6" suspension lift and run the stock driveshafts just fine.
4wheelcustoms.com has great prices on lifts and on the FSB site in the vendor section is a company selling the rough country lifts at discounted prices as well.
Old Dec 8, 2008 | 08:10 PM
Miketnf150's Avatar
Miketnf150
This is true. As posted earlier mine has a 6" and I didn't do anything to the drive shafts.
Old Dec 8, 2008 | 11:52 PM
greystreak92's Avatar
greystreak92
Originally Posted by bronco94
Bronco Handles great
4" suspension w add-a-leaf and 3" body lift
the only thing wrong with it is it doesn't fit in the garage
I went up 7" because I had 36" Ground Hawg radials on it
Hawgs were junk tires-Shook big time
had to cut bumper coners
but it looked cool
Not to be a nay-sayer here but there is one other thing "wrong" with this setup. Neither lift manufacturer will honor the warranty on the lift or components of the lift anymore. The use of both types on the same vehicle is so risky that the manufacturers won't stand behind their products if they are used together on the same vehicle. Ask any manufacturer before you do this if you doubt my words.
Old Dec 9, 2008 | 08:12 AM
jimford1's Avatar
jimford1
So what else do you need then??
Old Dec 9, 2008 | 05:00 PM
bronco94's Avatar
bronco94
Noit worried about warranties on lift kits of the bronco
Warranties are for people that worry too much
Old Dec 10, 2008 | 12:49 AM
greystreak92
If warranties are for people that worry too much then ask yourself why you aren't worried that the MAKERS of these components won't stand behind their products because the installation of both is so unsafe that they won't be held responsible for the potential damage and loss. Worrying isn't a bad thing when it comes to vehicle safety. The problem is too few people DO worry about it. So we end up with things like people yammering away on their cell phones while they drive, running around at night with a headlight or taillight burned out, and installing an unsafe combination of aftermarket products into their vehicles just to name a few things. (In short if you want to argue the point, come up with a better reason because that one doesn't hold water).
Swapping tires larger than 32's should really include the swapping of axle gearing to at least 4.11:1 ratio for 33's and even taller for larger diameter tires. The formula for calculating the gearing needed for the tires you've selected is listed in the red link in my signature.
Old Dec 10, 2008 | 04:34 PM
bronco94's Avatar
bronco94
there is no arguement because I agree with you
Anytime YOU change a vehicle from factory specs you run the risk of failure
Do you think that lifting a vehicle and putting much larger tires on it is safe
That is why they have lift laws
In Wisconsin it is legal and states it as such to have both body and suspension lifts on same vehicle
If it was unsafe. Why would the state make laws saying differance. LOL
I know your point and do agree with you.
The manufacturers of these kits do not want to be resposible for anything
I am really suprised that any of them actually have warranties
They should have the warranties only active when installed by a "QUALIFIED" and a factory trained shop
How can the manufacturers be responsible for work done by amatuers
We all need to take some responsibilty for our actions
Old Dec 10, 2008 | 04:46 PM
bronco94's Avatar
bronco94
I wouldn't recommened putting on a bodylift
I did it a long time ago 7+ years ago
Learned alot since then
Lifting vehicles for on road uasage is not safe
If I did it again the only lift kit I would put on is the one from AutoFab
1980-1996 Bronco F150 4x4
They redo the IFS arms and use the factory pivot mounts, much safer in my opinion
Get some of those awesome fiberglass front amd rear fenders
fiberglass tailgate and that cool looking front bumper
jgdrcr
Aug 29, 2016 01:30 PM
Chris Popanz
23
Nov 29, 2015 11:14 AM
steve33444
30
Dec 16, 2014 10:06 PM
trevorrules
Dec 15, 2013 09:04 PM
55 M-100
Offroad & 4x4
Feb 1, 2010 11:49 AM
