Front diff removal
Old Nov 15, 2008 | 09:06 PM
sextons's Avatar
sextons
Front diff removal
I am in the process of replaceing my front axle inner seals. I found a number of great posts about ball joint replacement etc. that cover the front seal replacement, but I am to the differential removal and can't get it out. Can someone explain to me what has to be removed to get the chunck (diff) out. I thought it was just the two bearing caps. (4 bolts). This is a great site!
2003 F-350 7.3L CC LWB 4x4
Old Nov 15, 2008 | 10:29 PM
zack7.3's Avatar
zack7.3
Try this link...There is a lot of information here.
Pirate4x4.Com - Extreme Four Wheel Drive
Old Nov 16, 2008 | 09:11 AM
sextons's Avatar
sextons
Thanks for the info. Plenty of info on that link. It will take some time to read through it all. Nice looking 99 1/4 you have.
Old Nov 16, 2008 | 10:56 AM
cangim's Avatar
cangim
Which side of the axle is leaking on yours? My buddies is leaking on the driver side, his is an 01.
Old Nov 16, 2008 | 12:45 PM
zack7.3's Avatar
zack7.3
No problem. Thanks, I call it a 99 1/4 because I have the late 99 motor and the early 99 suspension.
Old Nov 16, 2008 | 12:49 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
You have to:
remove:
wheels
brake calipers
rotors
hub lockouts
unit bearing hubs
axle shafts
and then, you can pry the carrier out. Trust me, she's a bitch!
Old Nov 16, 2008 | 09:57 PM
sextons's Avatar
sextons
Thanks for confirming that it is a female dog to get out! I don't have any problems spending time, as long as I know that it will come out. What did you use to pry on/with? Did you change the inner seals. If so, what did you use?
The drivers side was the leaking side. The lube as 25% water by the time I got to it. It is my boys truck, and you know boys......
Old Nov 16, 2008 | 10:38 PM
PowerstrokeJunkie
I was just in there before my knee surgery, i was changing the ring and pinion... To push them out i used a big socket that matched the diameter with a long extension, and just tapped (hardly) with a hammer from the outside of the axle tube. Might as well do both of them while you are in there. Make sure you keep the shims in order on the sides of the carrier bearings... thats important, lol
Old Nov 19, 2008 | 11:09 PM
sextons's Avatar
sextons
WE just finished putting the differential back together tonight. The center seals were a piece of cake. I did buy a very nice tool from QUAD 4 x4 that I used to install the seals. The carrier came out with no problems. We will install the axles tomorrow night after replacing the short outter shaft then put the rest back. Thanks for all of the help.
Old Nov 20, 2008 | 11:12 AM
cangim's Avatar
cangim
Do you have the part numbers for the inner seals? Napa is kinda vague on what is what.
drus136566
Jun 17, 2013 10:52 AM
Ron Kelley
Nov 2, 2007 10:40 PM
Rancha9
May 14, 2006 12:09 PM
KJKozak2
Jan 16, 2003 08:58 PM
