Quick help please. Looking for BPP.
Old Nov 15, 2008 | 04:15 PM
Reidicus's Avatar
Reidicus
I am looking for a Brake pedal position sensor. Mine was rubbing on a wire harness under the dash and dosen't. Now to get the shifter out of park, I have to stand on the break pedal (which feels all squishy now) or reach under and push the sensor myself. I called the dealer and they wern't much help. They think they found the part which costs $99.98 and the replacement bracket for $92.49. I think im being stiffed.
Anyone know a part number or a cheap place to order from?
Old Nov 15, 2008 | 05:08 PM
jmaskew's Avatar
jmaskew
Check this site sponsor out:
Th!nk Parts Guy
Good luck! That issue seems like a real challenge.
Old Nov 15, 2008 | 05:22 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Fix the rubbed wire.....cut - splice - solder - tape!
Old Nov 15, 2008 | 05:28 PM
Reidicus's Avatar
Reidicus
No need. Didnt get all the way through. No exposed wires.
But next time your in you Six Oh! take a look at what is attached to the brake pedal. You'll have to the reverse limbo to look under the console. Little piece with a yellow backing. You can pull the front black piece forward and it will dissenguage you shifter and turn on your rear lights. I wish I could fix this asap! Its the little things that get you frustrated.
Old Nov 16, 2008 | 06:44 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
I have a similar problem, I'll have to check that out! Mine won't come out of Park at all while running, so I simply start it in Neutral.
Glasman
13
Oct 1, 2014 09:15 PM
MauleOne
Aug 27, 2012 09:22 PM
powerstroker100
Sep 23, 2011 09:12 PM
14psd
Jan 25, 2007 12:43 AM
xfordtech
Feb 7, 2006 02:25 PM
