water proofing for muddin?
Old Nov 18, 2008 | 08:37 PM
fordguy300's Avatar
fordguy300
ok the 89 in my sig
i hit water or anything in mud if its really wet it gets on the distributor im guessing and shorts something out as it gets all ****y running and misses then it will quit then you start it it will run for a while bad then clear up
my 87 never did this even when it flooded water was surrounding hte motor and it ran fine
so the question is is there away to i guess "waterproof" the distributor and do you just put a sealant from the wire to plug?
any help is appreciated
Old Nov 18, 2008 | 09:16 PM
ottawaguy's Avatar
ottawaguy
Awhile back I was having some "moisture" issues we'll say...Even damp mornings would be enough to give me trouble starting her. I, after some research here, lubed up both ends of each plug wire and coil wire with die-electric grease. I used a liberal amount and found it solve my problems.
I found that I need to re-apply about every 6 months...or at least check them. Usually a fresh application is in order.
This may or may not solve your problem, but it may help and it is very cheap(under$10). I will also mention that It have the same engine as yours...4.9 EFI
Good luck and keep us posted.
Old Nov 18, 2008 | 09:17 PM
cyclegrip's Avatar
cyclegrip
Had this same problem. For some reason, it just went away after awhile, maybe it got used to being wet
Silicone maybe?
Old Nov 18, 2008 | 09:50 PM
fordguy300's Avatar
fordguy300
yea i am going to try the dielectric grease i heard of it and for 10 bucks it cant hurt ill let ya know wat happens...thanks
Old Nov 18, 2008 | 09:55 PM
ottawaguy's Avatar
ottawaguy
You bet..... a good time to clean the battery posts and give them a lube as well.
Old Nov 19, 2008 | 02:09 AM
TexasGuy001's Avatar
TexasGuy001
You could try the rubber boot that they used to run on 5.0 Mustangs and I think maybe CrownVics. I put one on my truck. It was about 10 bucks.
Old Nov 19, 2008 | 03:30 AM
Opossum's Avatar
Opossum
Two things;
1. People use dielectric grease on the contact portion of the wires/plugs. This is incorrect dielectric grease is used as an insolator use it only to help the boots seal.
2. Spray WD-40 inside the distributor and cap, wait for it to "dry" then reinstall and go. This is actually what WD-40 was engineered for. WD stands for Water Dispersant, 40 is formula 40. NASA made it to prevent condinsation on the circuts in the spacecraft.
Old Nov 19, 2008 | 07:36 AM
1966Tbird's Avatar
1966Tbird
i use rtv silicone and sealed the plug ends to the plug wires, sealed the bottom of the distributor cap, put some around the terminals on the distributor cap and sealed the wires to the cap, and also used one of the mustang boot cover thingies, sealed up pretty good but i found my problem was all the fuel injection wires were not sealed, so i switched to a carb and threw the fuel injection crap away
and extend your vent lines....
