Sponsored by: Auxito
1998 401 code
Old Nov 14, 2008 | 05:33 PM
kojack's Avatar
kojack
Red face 1998 401 code
have cleaned throttle body, changed egr valve and goes off for about 30 miles,have air thur vents changed at higher rpm.s to defrost,need help,what else can it be?????????
Old Nov 14, 2008 | 06:04 PM
Bobby82490's Avatar
Bobby82490
Not to be rude... but grammer is your friend.
Anyway did you clean the TB or did you clean the TB EGR ports? The A/C through the defroster is a vaccum problem.
Old Nov 14, 2008 | 07:39 PM
kojack's Avatar
kojack
1998 ford
yes i did, cleaned out both,and like i said if i turn my air on at higher rpm's it starts blowing out the defrost till i let up.
Old Nov 15, 2008 | 05:21 AM
Bobby82490's Avatar
Bobby82490
Your DPFE sensor is probably bad then. As for the A/C, I cant really help you, Im not familar with the vaccum operated A/C. Do a search and you will see many threads with the same problems as you.
Old Nov 17, 2008 | 10:06 AM
KingRanchMan02's Avatar
KingRanchMan02
There is a vacuum line through the firewall in the area of the battery that supplies vacuum to the heater controls.
Take a look at that line and the lines that run over into the fender well where the vacuum accumulator is located. Some guys find that the battery has dumped some acid out that has eaten through the vacuum lines.
Has the truck ever sustained damage in the right front? If so, the accumulator may have been damaged. Good luck!
Old Nov 17, 2008 | 10:19 AM
kojack's Avatar
kojack
1998 f 150
thanks john,have found that problem before but have looked at them again and don't see any line problem,,,,thank's again
shark1979
35
Nov 10, 2010 10:02 AM
ford360
Oct 16, 2006 01:10 AM
corpuspits
13
Jul 2, 2006 11:28 PM
fightercowboy
1997 - 2003 F150
20
Aug 26, 2004 12:39 AM
grey77
2004 - 2008 F150
Aug 3, 2004 06:33 PM
