Oil Cooler
Old Nov 13, 2008 | 10:21 PM
ewales's Avatar
ewales
Oil Cooler
Hello
Has anyone come up with a method to pressure test the engine oil cooler. I have an 05 that has what appears to be good engine oil in the pan (what is left). But what is in the cooling system is an engine oil/coolant mix. The only place I see it coming from is the engine oil cooler. Any thoughts would be greatly appreciated.
Old Nov 13, 2008 | 11:07 PM
3000 FPS's Avatar
3000 FPS
Most likely it is coming from the oil cooler. The oil pressure being much greater than the coolant pressure it leaks into the coolant and shows up in the degas bottle.
Old Nov 13, 2008 | 11:40 PM
ewales's Avatar
ewales
That was were my thoughts were at, the only thing that made sense. What are your thoughts on flushing the cooling system ?
I think with alot of fresh water and simple green the system can be saved.
Old Nov 14, 2008 | 07:09 AM
bismic's Avatar
bismic
Here are a few resources for oil in the coolant:
<TABLE style="WIDTH: 548pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=731 border=0 x:str><COLGROUP><COL style="WIDTH: 548pt; mso-width-source: userset; mso-width-alt: 26733" width=731><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 548pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: #ccffff" width=731 height=17>
TSB on oil in coolant:
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 548pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: #ccffff" width=731 height=17 x:str="07-23-14 NOV 07 Cooling System - Oil in The Engine Coolant ">07-23-14 NOV 07 Cooling System - Oil in The Engine Coolant </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 548pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: #ccffff" width=731 height=17 x:str="08-11-3 May 08 COOLANT LOSS - 6.0L ">08-11-3 May 08 COOLANT LOSS - 6.0L </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 548pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=731 height=17>
Miscellaneous:
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 548pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=731 height=17>http://ford****************s.com/downloads/6.0L%20Oil%20Cooler.pdf</TD></TR></TBODY></TABLE>
