Sponsored by: Real Truck
Door Ajar Sensors
Old Nov 13, 2008 | 08:13 PM
slappysdump's Avatar
slappysdump
Door Ajar Sensors
Ok--I've read through alot of threads regarding the door ajar light/dome light issue that can usually be solved with WD-40 sprayed into the door latch. However my light is still on, and no dome light when I open the drivers door--after numerous sprays and opening/closing over a period of days so I need to replace the sensor right? I called the local Ford dealer and tell the parts guy I need a new latch-no prob $37.00, he asks if I need the door ajar sensor too--wait a second its one piece right--no he says its two pieces so I order just the sensor ($30.00) and it should be here tommorrow-cool. So I take the old latch out of the door and it looks like one piece (latch and sensor) to me. Does anybody know how to seperate this unit or is the dealerships parts guy incorrect? Its kind of a PIA to get the latch out so I want to get it right the first time. Sorry for the long post and thanks in advance for any insight.
Old Nov 13, 2008 | 08:43 PM
ameinig's Avatar
ameinig
The door ajar switch comes out with a quarter turn once the connector is removed. You will see what I mean when you get the switch. You can do it while the latch is in the door but it is kind of a PITA. Removing the latch is too, so choose your poison!
Old Nov 13, 2008 | 08:58 PM
slappysdump
Is it the slightly angled orange piece of the door latch assembly??
Old Nov 13, 2008 | 10:33 PM
ameinig's Avatar
ameinig
It is slightly angled out of the bottom of the latch. I don't remember it being orange. Mine (1999) was purple I believe. Yours may be orange. It will have a 2 wire connector on it. From memory, I think that you can get it in and out without taking the latch out of the door. I think that I ended up removing the latch fasteners and leaving the rods connected so that I could rotate the latch slightly. It takes a reasonable amount of force to turn the sensor out of its detent, and I couldn't get a good enough grip with the latch in its installed position.
Old Nov 14, 2008 | 10:20 AM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
here is what he is looking at bottom right of page, the latch is 218A42 the 14018 is the switch XF2Z14018AD LH front.
Ed
Old Nov 14, 2008 | 11:16 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Or you could have tried the WD40 repair...most all Fords have this problem one time or another....Spray the latch ***'by with the WD40 liberally.... open close door a number of time....light goes out. If not respray and wait overnight....if THIS didn't work, THEN change the switch.
Crud gets into the switch and stops it from working correctly. A few days after it starts working correctly, give it a spritz of good silican spray to lube it.
Old Nov 14, 2008 | 03:54 PM
slappysdump
Got the new sensor/switch from the dealer today and got it put in the latch assembly--hope to get the door back together in the morning. The old switch was froze up tight--no amount of wd-40 was fixing it. Thanks for the replies...I'll let you know if the light on the dash goes out when its back together.
lud04X
Feb 24, 2013 01:41 PM
Jbrown8988
Jan 2, 2011 01:25 PM
live2hunt
Mar 17, 2005 10:04 PM
