Sponsored by: Real Truck
Tie Rod Ends...
Old Nov 14, 2008 | 12:41 PM
triskit16's Avatar
triskit16
Tie Rod Ends...
I was wondering if there was a quick an easy way to check the tie rod ends on my F250. Im going on a trip soon and would like to have some peace of mind on the way down there!
Old Nov 14, 2008 | 01:22 PM
CampSpringsJohn's Avatar
CampSpringsJohn
If you jack one wheel up off the ground, that should releave the stress on both tie rod ends. With this done, you can grab them and see if they are loose. You can also grab the tire and see if you have any movement.
Old Nov 14, 2008 | 04:15 PM
senix's Avatar
senix
yup I do beleive that is going to be the only way, might want to grease them too if you have the grease fittings.
