When you decide to snoop around, look for the probe on the driver's side exhaust manifold or up pipe to the turbo. That will be the most likely place to put the probe preturbo.
Looking at mine this morning, it was pretty steady at 550 at 70 MPH. Boost was at 4psi. When I left the house, it was about 52*.
You should see something like this in your manifold or up-pipe (mine is in the up-pipe, as you can see):
600* is pretty much normal. It depends on ambient temp also. Cooler air going in, cooler temps going out.
