Cleaning and reusing IAC valve ?????
Old Nov 12, 2008 | 11:51 AM
78crewcabjohn's Avatar
78crewcabjohn
I have replaced my IAC valve for the second time due to the stalling issue at low idle on my V10. The autozone replacement lasted 3 years....out of warranty of course! Has anyone had luck cleaning and reusing the IAC? The one I just replaced was dirty inside (dark or black dust). Is that a due to a bad air filter or normal condition??? I kept it in hopes it could be cleaned. THANKS JOHN
Old Nov 12, 2008 | 12:12 PM
rlh68050's Avatar
rlh68050
Yes you can try to clean the IAC, use carb cleaner. The black soot it carbon buildup from the fuel vapors and oxygen mixing.
Old Nov 12, 2008 | 04:11 PM
ReAX's Avatar
ReAX
It's normal. I use a little carb cleaner and work the piston alittle and re assemble.
Old Nov 13, 2008 | 01:48 PM
78crewcabjohn
Thanks for the suggestions. I'll clean my old part and keep it on the shelf ready to go for the next time. At least I'm getting good at changing that part. Seems like a common problem. JOHN
Jonathan Stone
Aug 24, 2016 04:11 PM
Jonathan Stone
General Automotive Discussion
Aug 24, 2016 04:10 PM
DangerRanger5280
1983 - 2012 Ranger & B-Series
Jan 14, 2016 07:08 AM
86ford185
17
Dec 31, 2014 02:55 PM
M_Jennings
Sep 9, 2014 04:51 AM
