66 Clutch Question
Old Nov 12, 2008 | 11:42 AM
rgzsr66's Avatar
rgzsr66
66 Clutch Question
I recently acquired a 66 F100 with a 302 & an automatic. I'd like to swap out the automatic for a 4 speed since it was a factory stick. I need to find an entire clutch pedal assembly. Does anyone know if any other years are the same as 66 so I can start my search? Any help would be much appreciated.
Old Nov 12, 2008 | 11:57 AM
bertha66's Avatar
bertha66
65-66 2wd truckswill work. Also sense your truck would not of come with a 302, would of been a 352 if it had a v8, so the linkage maybe something differant
Old Nov 12, 2008 | 12:22 PM
rgzsr66's Avatar
rgzsr66
Thanks. Not sure what it had originally, I need to get it decoded. It has a 1970 302 now with the FMX transmission.
Old Nov 12, 2008 | 12:29 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Engine/trans swapped.
First year for the 302: Passenger cars: Spring of 1968 / F100's, Bronco's and Econolines: 1969 model year.
Uh...It doesn't have that trans, as the FMX was never used behind a 302 of any year, car or truck.
It's a C4 = 11 trans pan bolt holes.
If the trans pan has 14 bolt holes, it is an FMX, but the engine will (prolly) be a 351W (introduced in cars 1969), it might even be a 351C (introduced in cars 1970).
351W/351C's used C4's, FMX's, C6's.
302/351W = 6 valve cover bolts / 351C = 8 valve cover bolts.
No 351W's were installed in F Series trucks and Bronco's till 1981. 351C = 1970/74 passenger cars only.
Post the TRANS code, found on the Warranty Plate, located on the left door face below the latch.
The VIN's 4th digit is the engine code. 1966: A = 240 I-6 / B = 300 I-6 / Y = 352 2V.
Old Nov 12, 2008 | 12:47 PM
rgzsr66's Avatar
rgzsr66
Thanks for the help, much appreciated.
I'll check it all out and get back to you. I was just going by what he seller told me about the transmission.
The selling point on this one was rust free straight sheetmetal from NC. It's tough finding that here in PA.
Old Nov 12, 2008 | 12:52 PM
NumberDummy
No rust here in LA LA Land, either.
If you wish, post all the codes found on the Warranty Plate.
It can all be decoded right here by several of us.
You will then know what the original configuration was, and a bunch of other info related to the:
COLOR / AXLE / BODY-Interior color, type of material / Where the truck was assembled / City it was ordered from / Other info.
Old Nov 13, 2008 | 05:41 AM
ddavidv's Avatar
ddavidv
Ha, that's what I did. I imported one from NC!
There are NONE of these trucks left here unless they are filled with Bondo.
Be sure to sign on with our local group--it's free--and you'll find pretty much most of the guys who own these things around you.
Slick 60's :: View Forum - Mid-Atlantic Chapter
Old Nov 13, 2008 | 08:08 AM
rgzsr66's Avatar
rgzsr66
Thanks, I'll have to sign up.
Here's the info. on the warranty plate.
VIN: F10AE862461
Warranty Plate Info:
115 WM F100 B81 C 09
05000 129 4000 25
The trans does have 14 bolts on the pan. There are 6 bolts on the valve covers and in the pile of receipts the previous owner gave me there is a receipt from Jasper Engines from 2001 for a 1970-74 302 engine.
Old Nov 13, 2008 | 09:12 AM
NumberDummy
F10AE862461 / 115 WM F100 B81 C 09 05000 129 4000 25
F10 = F100 2WD
A = 240 1V I-6
E = Mahwah NJ Assembly Plant
862461 = 1966
115" Wheelbase
WM: W = Marlin Blue / M = Wimbledon White
F100 2WD / 5,000 lbs. GVWR
B81: B = Medium Blue Crush Vinyl & Medium Blue Cody Pattern Woven Plastic / 81 = 81B Custom Cab
C = Ford Type 3.03 3 Speed all Syncromesh Manual Transmission
09 = Ford 9" / 3.70-1 / non Limited Slip / 3300 lb. Rear Axle Ceapacity
5,000 lbs. Gross Vehicle Weight Rating
129 Net HP @ 4000 RPM
25 = Richmond VA Ford District Sales Zone Office, where the original selling dealer ordered the truck from.
No Ford truck with a 302 ever used an FMX transmission.
1972 & 1973 Galaxies & Mustangs:
Some 302's used C4's, some 302's used FMX's.
Info on FMX trans: 1965/72 & 1973/79 Ford Passenger Car Parts Catalogs.
66f250
Nov 1, 2014 06:49 PM
rwrogers
Mar 8, 2014 05:54 AM
thenap1
Apr 6, 2011 04:47 PM
thenap1
Feb 1, 2011 08:06 AM
ford66
Aug 29, 2009 11:49 AM
