automatic to stick
Old Oct 31, 2014 | 08:12 PM
66f250's Avatar
66f250
automatic to stick
Hey guys, I'm looking at changing my 66f250 automatic to a four speed stick. Was just curious if the break and clutch assembly under the dash from a 79 (since i already have one) would work with minimal fabrication in my 66 cab. Or would i be better off looking for one out of a 66 somewhere? Thanks, 66f250
Old Nov 1, 2014 | 09:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 66f250
Hey guys, I'm looking at changing my 66f250 automatic to a four speed stick. Was just curious if the brake and clutch assembly under the dash from a 79 (since i already have one) would work with minimal fabrication in my 66 cab. Or would i be better off looking for one out of a 66 somewhere? Thanks, 66f250
You will need all the clutch linkage and the pedals from a 1965/66 F100/250 2WD. Finding these parts in your area will not be easy.
The FE bell housing is the same: 1965/66 F100/250 352 2WD - 1966 F100 352 4WD - 1967 F100/350 352 - 1968/76 F100/350 360/390.
Any other year inre to clutch linkage, clutch and brake pedals, the bracket they suspend from...you will be opening a HUGE can of worms!
1973/79 F100/350 for example:
TWENTY TWO different brake pedals - NINETEEN different master cylinders - SEVENTEEN different power brake boosters - SEVEN different clutch pedals - FIVE different brackets the pedals suspend from, I kid you not!
Old Nov 1, 2014 | 06:49 PM
resonateur's Avatar
resonateur
Let me know if you need any of the clutch linkage and pedal setup. I have all that from a '65, including the whole pedal bracket with clutch and brake. See my listing (parting '66 and '65) and PM or email me.
Gcwstang
Jul 12, 2014 05:32 PM
gofrogs69
Oct 30, 2012 06:21 AM
rwpurves
Mar 19, 2011 09:28 PM
krakerjak
Feb 9, 2011 09:58 AM
