Alignment specs
Old Nov 12, 2008 | 11:37 AM
68gte's Avatar
68gte
Alignment specs
Can anyone provide the alignment specs on a 1992 Explorer XLT w/4X4, 4.0L, & Manual trans? Thanks in advance!
Old Nov 13, 2008 | 09:51 PM
steve(ill)'s Avatar
steve(ill)
i dont know the "exact" numbers for you truck, but what i do is put a level on the side of the tire and see that the top of the tire is tilted in toward the motor about 1/4 inch more than the bottom. if the tire wears funny, then you can adjust a 1/16 inch more or so... also measure the toe in. distance between the front of the tires should be about 5/16 inch less than the distance between the rear of the front tires. again, you can increase that slightly if the tire wear shows the need.
Old Nov 14, 2008 | 08:32 AM
68gte's Avatar
68gte
Thanks for the reply, but I really need the exact specs. Some one out there can look them up, please....
Old Nov 14, 2008 | 07:42 PM
steve(ill)'s Avatar
steve(ill)
im not sure exactly where your going 68, but i only use the factory settings as a first guess. after 30k miles i check the tires and determine what needs to be "changed" to get better tire wear. the factory specs are a good starting point, but not really exact. normally i dont even care what the truck is set at now, i look at the wear and determine what it needs next.
Old Nov 14, 2008 | 08:17 PM
68gte's Avatar
68gte
I got em, here they are just in case any one else needs them:
MIN PREF MAX
CAMBER
LF (DEG) -.25 .25 .75
RF (DEG) -.25 .25 .75
S/S .50
CASTER
LF (DEG) 2.0 4.5 7.0
RF (DEG) 2.0 4.5 7.0
S/S .50
TOE
(DEG) -.19 .06 .31
Adigo
Feb 4, 2016 09:28 AM
hhcobra
Jun 3, 2012 09:38 AM
Mudslinger21
Aug 2, 2009 07:49 PM
hladun
Dec 19, 2004 06:53 AM
sandman3510
Jul 20, 2004 12:30 PM
